Author: Subject: Suspension analysis software?
craig1410
posted on 12/4/09 at 01:10 PM Reply With Quote
Hi guys,
Just wondering if there is any freely or cheaply available software which allows you to put in the dimensions of your suspension/steering system and then perform what-if analysis? You know, something where I can put in the various arm lengths and angles and then calculate camber, caster, toe etc and then make some changes and see the effect.
I don't mind if this is a spreadsheet or an actual program as long as it's not expensive.
Craig.
Theshed
posted on 12/4/09 at 02:07 PM Reply With Quote
I use susprog - but its not cheap!
craig1410
posted on 12/4/09 at 02:21 PM Reply With Quote
Are there any demo versions of susprog available? Perhaps with limited functionality?
Craig.
brianthemagical
posted on 12/4/09 at 02:25 PM Reply With Quote
The best has got to be the Lotus Suspension software, but finding it will be very hard. And it may be a bit complex to use. Not sure on price or anything like that, no doubt it's not cheap.
