clairetoo
| posted on 14/4/09 at 06:53 PM |
Flexy exhaust tubing ?
During the epic 300 mile motorway run down to Detling at the weekend , I came to the conclusion that I need to do something about exhaust noise on my
Fury
The exhaust's exit the sills just ahead of the rear wheel's - so there's one right next to my ear (relatively speaking) . I had a
good look at possible routing for rear exit pipe's - and it's do-able , but not easy with rigid pipe .
Question is - if I use flexi pipe , am I likely to have any problem's come MOT time ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
| posted on 14/4/09 at 06:55 PM |
As long as the pipe is secured and not leaking and the system is not too noisy you shouldn't have any problems
blakep82
| posted on 14/4/09 at 06:59 PM |
i've seen it for sale in accessory shops so shouldn't see its a problem for MOT
________________________
Paradoxia0
| posted on 14/4/09 at 07:04 PM |
Hi
I had to use a short section of flexi pipe to join my manifolds to my exhaust before I got some proper bits made - went through SVA like that so I
cannot see an issue for MOT!
Mark
EDIT - in fact you can just about see it on my avatar, a piece about 12-18 inches long (one on either side of the car )
[Edited on 14/4/09 by Paradoxia0]
mark chandler
| posted on 14/4/09 at 08:51 PM |
Best avoided if possible, its not the best stuff and makes a bad job of it, much better to get artistic with some bends and welder.
A simple straight run for a bit of flex is very different to trying to wrap it around a chassis and axle.
Regards Mark
owelly
| posted on 14/4/09 at 08:53 PM |
Fit the flexi stuff and then blob some welds along it to make it rigid. Then take it to an exhaust maker and get them to copy it.
http://www.ppcmag.co.uk
MkII
| posted on 14/4/09 at 09:02 PM |
flexi exhaust tube is not good as a permanant soloution in time it will start to leak. m.
stevebubs
| posted on 14/4/09 at 09:19 PM |
Fury
No - but it's not a "permanent fix".
"Temporary" flexi has been on my Fury for 5 years now.....no issues @ MOT...
stevebubs
| posted on 14/4/09 at 09:20 PM |
PS Have you thought about a better silencer??
clairetoo
| posted on 14/4/09 at 09:22 PM |
Um..........not much chance of that - this has to be as locost as possible (tax/mot/insurance time )
I allready have some 2" flexi and suitable off cuts of pipe - I just need to work out if the axle will hit it as it will need to go between the
tyre and chassis , then up over the axle , and down under the fuel tank......at least six bends per side !
Claire xx
clairetoo
| posted on 14/4/09 at 09:23 PM |
I have ................ but I'd need two
Claire xx
Paradoxia0
| posted on 14/4/09 at 09:27 PM |
As others have said, it isn't great. Mine fell to pieces in about 500 miles.
Mark
There is no replacement for displacement...
owelly
| posted on 14/4/09 at 09:35 PM |
I wasn't suggesting that you bought the bends but got a company with a bender (titter) to craft you some. I've never met you but girls
have an inbuilt ability to flutter their eyelids and make things happen. I suggest this route for you. If your're an ugly pig, which I'm
sure you're not, get your hand in your pocket........
I used bike silencers. Very cheap and quiet.
stevebubs
| posted on 14/4/09 at 11:09 PM |
If you can weld, it may be worth considering building your own?
907 did some a year or 3 ago...just need to get someone to roll the sheet for you - everything else is available "off the shelf"
Quickest and easiest solution for long journeys may be earplugs?
