piddy
| posted on 23/4/09 at 10:33 AM |
Mondeo Hand brake cable
Hi.
Have any of you changed a Handbrake cable on a mk3 Mondeo?
I just wondered if there is an easy way.
It has a self adjuster can this be released?
jonesier1
| posted on 23/4/09 at 02:06 PM |
if its an early mk3 with then just pull on the cable to get it out from the t piece under the tunnel above the heat sheild,but most of them were
changed and the self adjuster was done away with and a manual handbrake was fitted with a 16mm adjuster nut above the exhaust .They are very common
for siezing up along with pads sticking in the carriers.
Gazeddy
| posted on 23/4/09 at 03:05 PM |
theyre easy if youve got access to a ramp.
i drop the xhaust off its rubbers to the flexi and support it. take the heat shield off then back off the adjuster simple as replace th cables and
rebuild on a ramp looking at half hour job
| posted on 23/4/09 at 08:54 PM |
Can be done easily without dropping the exhaust if you can get the car on a lift.
