Howlor
| posted on 29/4/09 at 02:18 PM |
OT - Oil Seal 52mm ID 115mm OD
Help,
Have a problem I need to resolve urgently, I am trying to find a shaft oil seal with either a 52mm ID or 2" but with an OD of about 115mm.
Thickness is 10mm ish.
Any ideas? I have been trawling the net but with no luck so far.
Many thanks,
flak monkey
| posted on 29/4/09 at 02:30 PM |
Try an engineering supplie company such as Hayley
http://www.hayley-group.co.uk/
Give your local branch a call, they will be able to source something if its available next day.
Sera
http://www.motosera.com
| posted on 29/4/09 at 02:54 PM |
RS 50 mm bore, 70 mm OD, 10 mm thick
is closest.
^^^ that is wee poor actually.
if you know EXACTLY the size you are after, then go to http://simplybearings.co.uk/shop/index.php?cPath=19_4463
closest is 52x90x10mm
but since you do not state EXACTLY what size you are after, there may be ones that are a closer match,
i've oredered from them before and they are pretty quick, have no min., order and don't charge and arm+leg for postage.
their search facility is nifty so go and play.
if they don't have it, I doubt you'll find it anywhere else.
oh, another place you could try is yatch and boat places, i.e. seals for propellor shafts?
[Edited on 29/4/09 by 02GF74]
Howlor
| posted on 29/4/09 at 03:00 PM |
Thanks for the help guys. I have tried Hayley group and they were similar to RS. I think I'll have to try a smaller OD and sleeve the pocket it
fits in to.
Thanks,
jacko
| posted on 29/4/09 at 04:43 PM |
Try Lodges in Hull, english st i bet they will have one or get you one
[Edited on 29/4/09 by jacko]
owelly
| posted on 29/4/09 at 07:45 PM |
Try BSL Brammer. They'll have something!
http://www.ppcmag.co.uk
