Author: Subject: MIG Welding dip
Paul (Notts)
posted on 7/5/09 at 09:23 PM Reply With Quote
MIG Welding dip
When I am MIG welding at college I dip the gun in a can of something quite often to stop the wire sticking.
Having just bought a Clark 151 welder what do I need to but ie what’s the stuff I dip the tip in called.
Paul
Too much wine tonight and I have to go to work in the morning
mark chandler
posted on 7/5/09 at 09:26 PM Reply With Quote
can of annti splatter spray, use it on the work and squirt into the nozzle
clairetoo
posted on 7/5/09 at 09:41 PM Reply With Quote
A little something a welding instructor once told me - anti-spatter spray is mostly oil , and burning oil fumes are highly carcinogenic
So be very sparing with it !
Its cuz I is blond , innit
Claire xx
Will weld for food......
Benzine
posted on 7/5/09 at 10:05 PM Reply With Quote
Mmmmmmm... dips
907
posted on 7/5/09 at 10:10 PM Reply With Quote
Who was it that used to say "The clue's in the name"?
I beleive it's called Tip Dip
Paul G
MikeR
posted on 7/5/09 at 10:55 PM Reply With Quote
eeek - didn't know about the splatter spray being oil!
I usually only coat the nozzle once every few uses, then let it dry / drip off + use the co2 feed to help remove excess.
Bought a huge spray bottle thingy (like a water mister) and hardly used any of it.)
posted on 8/5/09 at 06:17 AM Reply With Quote
yeah me too. so is that what you are suppose to do with it?
Arre you meant to spray it onto the metal you are welding?
not tired that as wouldn;t spraying what appears to be mostly water be a bad idea?
40inches
posted on 8/5/09 at 08:17 AM Reply With Quote
Some here http://shop.ebay.co.uk/?_from=R40&_trksid=m38.l1313&_nkw=welding+tip+dip&_sacat=See-All-Categories
