Author: Subject: Reverse light comes on with ignition
vinny1275
posted on 9/5/09 at 10:33 AM Reply With Quote
Morning all,
I've said I'll look at swmbo's sister's Mitsubishi carisma, which is showing the reverse lights as soon as you turn the key in the ignition. I'm just waiting for the workshop manual to download (another 12 hours!) so thought I'd ask here..
Anyone any pointers on where to look first, or where's the reverse light switch connector on the gearbox? I'm guessing that it's just getting a power feed, so there's a short somewhere, either that or the gearbox switch is nadged... anything else?
vince
blakep82
posted on 9/5/09 at 10:43 AM Reply With Quote
bad earth maybe? they do funny things.
at worst, remove the bulbs. reverse lights are not tested for mot
________________________
posted on 9/5/09 at 10:54 AM Reply With Quote
Probably a sticky reverse switch. Should be easy to find it, there's usually only two electrical items on a gearbox, the reverse switch and the speed sensor. Reverse switch is usually quite close to the selector mechanism.
