Author: Subject: Camcorders on a 7
stuart_g
posted on 21/5/09 at 10:55 AM Reply With Quote
Camcorders on a 7
Are Camcorders any good for use on a 7?
you can get some quite cheap that record direct onto an SD memory card, may be easier than buying a seperate camera and all the other gubbins to get it to work.
tegwin
posted on 21/5/09 at 11:01 AM Reply With Quote
Generally those cheap ones are cack...
Spend a bit more, get a second hand camcorder off ebay that has an AV-input socket and get a bullet cam from honk kong....
Should be doable for £200 if you shop around... that way you can mount the camera somewhere nice and secure!
www.verticalhorizonsmedia.tv
procomp
posted on 21/5/09 at 11:09 AM Reply With Quote
Hi
All i will say is GO PRO. £144.99
I have in the past as some of the locost racers have the cheap mustek cameras for £20-£40 results can be seen on many of the race vids in the racing section.
Cheers Matt
whitestu
posted on 21/5/09 at 12:48 PM Reply With Quote
I just use my digital camera [Pentax Optio A30].
Ther quality isn't brill but not bad either - have a look:
Youtube Link
Play in HQ for best quality.
Stu
posted on 21/5/09 at 01:10 PM Reply With Quote
For vidoeing blats I just use my normal dv tape sony camcorder attached to the roll bar with a clamp on mount. Works fine..... For racing when it might experience higher G forces I'd use a bullet cam though....
posted on 21/5/09 at 01:18 PM Reply With Quote
Youtube Link
Stu
That's not bad at all - probably helps it's a nice bright day, but even so.
How did you mount it?
dhutch
posted on 21/5/09 at 01:50 PM Reply With Quote
Ive got a ATKcam 2k, which was bought for me as a present for mountain biking.
- Its not awfull, but for £100 its awesome either. Espically as it seams to hit some sort of resonance with its refreash rate at just above tickover the causes the image to go all wavy. Can supply raw footage if you are interested.
Planning to try my digital (still) camera some time (£100 nikon s200 compact) and see how that fair. Foam of the microphone for wind.
- Would mount with a screw on flexable-leg mini tripod and gaffatape.
Daniel
procomp
posted on 21/5/09 at 01:54 PM Reply With Quote
Hi
Results from the GO PRO can be seen here as used by Track and Race car mag. Also check the spec of the unit. Mines going with me when i go diving again.
LINK
Cheers Matt
whitestu
posted on 21/5/09 at 02:00 PM Reply With Quote
That's not bad at all - probably helps it's a nice bright day, but even so. How did you mount it?
It's just a really cheap screw on camera mount [About £3] mounted on the roll bar using an aluminium strap.
The good thing about it is that in theory with a 2Gb sd card it will record for almost 2 hours. In practice the battery limits it to about an hour or so.
sorens2
posted on 21/5/09 at 02:22 PM Reply With Quote
http://www.youtube.com/watch?v=mSha-dSoMFo
Recorded with a JVC Mini DV camera.
Bracket on rollbar.
Soren S2
Gergely
posted on 21/5/09 at 02:46 PM Reply With Quote
I tried both the DV camera and Gopro as well.
The DV has nice image, great sound with an external microphone put under the scuttle, but the camera will suffer. The lens will get dirty (and wet if it rains...) and it doesn't like vibrations.
The Gopro was designed for this, you can place it anywehere, even the side of the car with the suction cup and it will hold it there at around 130 MPH - tested
The image is about half a PC screen, good enough... and it's fisheye, so really suits the application better.
Gergely
Our build pictures
wilkingj
posted on 21/5/09 at 03:01 PM Reply With Quote
Youtube Link
Stu
Stick a bit of foam or insulating tape over the audio / mike. It will reduce the awful wind noise.
Hmm.. I Should try that in me trousers
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 21/5/09 at 03:05 PM Reply With Quote
All our video are shot with a Panasonic DV Camera... held in place by a B.Hague Camera mount mounted on the centre bar on the Roll Bar... it's been very reliable and almost fault free with no ill effects to date.
S
PAUL FISHER
posted on 21/5/09 at 04:39 PM Reply With Quote
I use one of these,nice and locost,at less than £40,just plug it into any digital camcorder with a av in
http://cgi.ebay.co.uk/AIPTEK-Sporty-Cam-New-Sealed_W0QQitemZ320368556698QQcmdZViewItemQQptZUK_AudioTVElectronics_Video_Camcorders?
It gives not bad results for the money,even better if you click the HQ button
http://www.youtube.com/watch?v=AWGUUwFp2_4&feature=channel_page
