theconrodkid
| posted on 26/5/09 at 06:58 PM |
jb weld ?
i want to join an ally tube to an ally casting(inlet stub to manifold),
i was thinking of using some ally weld stuff that i got at a show,then i discovered an empty tube of jb weld,question is,is that strong enough or
should i weld it?
who cares who wins
pass the pork pies
MikeR
| posted on 26/5/09 at 07:08 PM |
i'd guess an empty tube won't be strong enough. One with some stuff in is supposed to be - although you'll have issues with doing a
tube as you'd got to get bits hot / keep them hot etc whilst doing the piece.
theconrodkid
| posted on 26/5/09 at 07:12 PM |
i had planed on putting the manifold on the gas cooker to heat it and keep it warm for the welding,jb seemed a lot less hassle
who cares who wins
pass the pork pies
MakeEverything
| posted on 26/5/09 at 07:23 PM |
I bought Alumiweld from Stoneleigh at the car restoration stand. The guy was really helpful and 1/2 the price of the self confessed
"Foreigner" selling a similar product. Id use that. I triedit on a peice of 1/4" ali plate and it works a treat. Need a small
flame though as a big lamp just cooks the whole lot. It might crack the casting as well if you dont heat it in the oven first.
Kindest Regards,
Richard.
theconrodkid
| posted on 26/5/09 at 07:32 PM |
cant find anyone selling alumiweld over this side of the pond,got any contact details?
who cares who wins
pass the pork pies
mad4x4
| posted on 26/5/09 at 08:22 PM |
Frosts sell it under a different name
Scot's do it better in Kilts.
GeoffT
| posted on 26/5/09 at 08:51 PM |
Here's a link to Welduk's offering :-
Aluweld linky
austin man
| posted on 26/5/09 at 09:07 PM |
make sure you have a stainless steel wire brush, its essential that you remove the oxidisation prior to joining the metals, done correctly you get a
really strong joint cant comment on whether it would be strong enough fro making a manifold as you have both weigh and the vibrations of the carb. I
have used the Weld UK stuff and had good results all be it on lighter gauge stuff
hillbillyracer
| posted on 26/5/09 at 09:24 PM |
JB weld is great stuff but how you contruct the joint wil be the important thing. If the two bits are just butted up together & a load of the
stuff plastered around the join then I dont think it'll do but if you make it so the tube is actually pushed into the casting & the two
parts have JB coating both mating surfaces before it's assembled & it's well worked in to fill any gaps then it may well work OK.
If you can get hold of the slow setting stuff it's stronger & withstands higher temperatures.
I JB welded 5th gear back onto the mainshaft of a Skoda pickup when the splines were stripped a couple a years ago, it was still going when I last saw
it before it was sold best part of a year later.
Chippy
| posted on 26/5/09 at 10:33 PM |
John, I have some Lumiweld, which is the first generation stuff. Your welcome to a stick, (and the loan of the S/S wire brush), if you can wait for
the next Newlands. Cheers Ray PS U2U me if you can wait, :-)
theconrodkid
| posted on 27/5/09 at 06:58 AM |
cheers for your replies peeps,ill order some loonyweld i think,ive got about 12" left over from the bit i bought 2 years ago,see how that goes
who cares who wins
pass the pork pies
GeoffT
| posted on 27/5/09 at 09:25 AM |
I see that there's a 'new generation' of these rods called HTS-2000. That look like they may be easier to use as you don't
seem to have to scratch through the oxide layer - anybody tried these?
