omega0684
| posted on 27/5/09 at 03:52 PM |
racetech temp sender
i need to get a racetech temp sender so that i can get a reliable reading of engine temperature on my racetech gauge obvioualy on the dash.
they come in three threads, M10x1.0, M14x1.5 and M16x1.5, how do i know which one to buy or is is a case of re-threading the mount in the pinto block,
to suit (i think the into block thread is 1/8 npt)
also it has another thread where you attach the wire for the sender, i have a female spade terminal on mine, again where can i get an adapter from
cheers
[Edited on 27/5/09 by omega0684]
Flamez
| posted on 27/5/09 at 03:55 PM |
cheers
Cut off the spade and re-crimp a terminal [round] connector on.
my build mac1motorsports
| posted on 27/5/09 at 04:08 PM |
You can usually get thread adaptors to suit. Re the connector- that's easy. As said cut it off and solder on a new one
