Author: Subject: Mini tool
speedyxjs
posted on 28/5/09 at 06:31 PM Reply With Quote
Mini tool
Does anyone know what this is?
Apparently it was used on an early mini.
Mini tool
Mini tool
posted on 28/5/09 at 06:36 PM Reply With Quote
It's probably to undo the the top and bottom balljoints from the upright. They are shimmed so you can compensate for wear, which involves a lot of screwing around
[Edited on 28/5/09 by MikeRJ]
blakep82
posted on 28/5/09 at 06:41 PM Reply With Quote
quite a big hex for that though...
hmm, i can't remember anything like that on my mini..
unless its for the tower bolts or whatever they were called, for the top bolts for the front subframe?
________________________
flak monkey
posted on 28/5/09 at 06:42 PM Reply With Quote
Cartridge oil filter spanner?
Sera
http://www.motosera.com
fov
posted on 28/5/09 at 06:47 PM Reply With Quote
I seem to remember it being for the subframe.
LBMEFM
posted on 28/5/09 at 06:59 PM Reply With Quote
Not sure what size it is but is it not for the clutch adjustment bolts, ie slaken one adjust then relock, situated on the cover on the left hand side on the engine
blakep82
posted on 28/5/09 at 07:02 PM Reply With Quote
actually, it looks a bit big for the subframe too...
trikerneil
posted on 28/5/09 at 07:03 PM Reply With Quote
Sure it's for a mini?
It's octagonal, looks like an immersion heater spanner to me.
Neil
ACE Cafe - Just say No.
blakep82
posted on 28/5/09 at 07:07 PM Reply With Quote
lol it is octagonal isn't it! oops, yeah, it looks perfect for imersion heaters....
Russell
posted on 28/5/09 at 07:22 PM Reply With Quote
It's definitely something to do with the clutch but I can't remember what exactly.
I'm a bilingual illiterate. I can't read in two languages.
mookaloid
posted on 28/5/09 at 08:01 PM Reply With Quote
What size is it?
posted on 28/5/09 at 08:15 PM Reply With Quote
Originally posted by trikerneil
It's octagonal,
Well spotted
The clutch throw adjuster is also a hex, and much smaller than that looks.
My second guess is a spanner for the octagonal spinners used on wire wheel MGs.
f1ngers
posted on 28/5/09 at 08:28 PM Reply With Quote
If it's 1 1/2" it's for the front balljoints. Can also be used for the flywheel nut although that is usually a 1 1/2" socket
Oh Yeah didn't realise it was octagonal!
[Edited on 28/5/09 by f1ngers]
posted on 28/5/09 at 08:34 PM Reply With Quote
Mini's were never fitted with octaganal nuts in any position .The flywheel bolt and the ball joint nuts are hexaganal.
DIY Si
posted on 28/5/09 at 09:08 PM Reply With Quote
as others have said, no way is it for a mini, as it's not a hex key!
Sun Tzu, The Art of War
Daddylonglegs
posted on 28/5/09 at 09:32 PM Reply With Quote
I'll second the immersion heater theory
Guinness
posted on 28/5/09 at 09:34 PM Reply With Quote
Mini tool
Mini tool
Ahh the very early minis with the immersion heater in the hot water tank. Used to warm the interior up in the winter and provide warm water to the washer jets to help remove ice / snow
http://www.diytools.co.uk/diy/Main/sp-39-3433-19054-faithfull-immersion-heater-spanner-cranked.asp
HTH
Mike
posted on 28/5/09 at 10:55 PM Reply With Quote
I still have all my old spanners from when I had Minis and none of them look like an immersion heater spanner
smartfazer
posted on 29/5/09 at 06:11 AM Reply With Quote
It looks like an immersion heater spanner to me.
Ciao4now
woodster
posted on 29/5/09 at 09:18 AM Reply With Quote
if its 86mm or 3 3/8 A/F its an immersion heater spanner
Marcus
posted on 29/5/09 at 11:44 AM Reply With Quote
Looks like a spanner to remove the badges form an MG
Marcus
Because kits are for girls!!
posted on 29/5/09 at 06:33 PM Reply With Quote
It could fit the rear hub nut on something like an Austin Cambridge or Morris Oxford , ISTR the were octaganal?
MikeR
posted on 29/5/09 at 06:44 PM Reply With Quote
i keep thinking fuel tank - but can't think why.
smart51
posted on 29/5/09 at 06:52 PM Reply With Quote
If it's 1 1/2" then it will do the front ball joints. I opened out an adjustable spanner and welded it
posted on 29/5/09 at 09:33 PM Reply With Quote
Square peg in a round hole??
