Author: Subject: water flow question
omega0684
posted on 5/6/09 at 11:31 AM Reply With Quote
water flow question
the outlet on the pinto thermastat housing is 32mm and i have reducer on the water pump outlet from 38mm to 32mm, but both the inlet and outlet on my rad are 26mm, obviously i can put reducers in the pipe work to get them to match, but how does this have an effect on the cooling efficiency? if it has any effect that is?
answers on a postcard........
Alex
Mr Whippy
posted on 5/6/09 at 11:35 AM Reply With Quote
it's just speeding the water flow up through the pipes, which then drops drastically in the radiator before again speeding up out the outlet hose
don't worry about it
AndyGT
what car is the rad from?
omega0684
posted on 5/6/09 at 11:40 AM Reply With Quote
it was a custom built rad for a zx12 rush
mcerd1
posted on 5/6/09 at 11:50 AM Reply With Quote
I wouldn't worry about it Alex, as long as the engine temp. is about right
the rad is probably way OTT for you engine anyway....
...or are you thinking about engine upgrades again ?
[Edited on 5/6/09 by mcerd1]
posted on 5/6/09 at 11:52 AM Reply With Quote
Ain't a problem as long as the reducers are gentle. If you had a sudden change in bore you'ld get some funky flow going on which might upse the coolant flow.... As long as you don't it's not a problem, the coolant will simply flow quicker through the narrower tube.
The big question I suppose is whether a radiator designed for a zx12 will be sufficient for a pinto. I suppose it's all to do with the differences in efficiency, BHP levels etc..... Should suffice given the huge amount of air entering a Seven's nosecone....
omega0684
posted on 5/6/09 at 12:07 PM Reply With Quote
i've been googling for half hour and im struggling to find 45 degree reducing hoses, im after 32mm-25mm, can anyone help?
or do they only come in 90 degree reducers and straight reducers
[Edited on 5/6/09 by omega0684]
James
posted on 5/6/09 at 12:18 PM Reply With Quote
There's a fair few to choose from here:
http://www.rallydesign.co.uk/index.php?manufacturers_id=21&osCsid=mtass72b2qrus11u9e10omn5l7
maybe they'll have what you want.
No reason you can't have separate 45° and reducer though... apart from the cost! lol!
Vindi_andy
posted on 5/6/09 at 12:30 PM Reply With Quote
You still struggling with your plumbing alex
I believe they have only been made in straight or 90 degree so far.
There will be no moulds for 45degree reducers but you could try contacting Viper performance hoses http://www.viper-performance.co.uk/ to see if they could make the but there will probably be a minimum order qty and a setup premium
[Edited on 5/6/09 by Vindi_andy]
omega0684
posted on 5/6/09 at 01:15 PM Reply With Quote
yeah, im thinking now that the front end design of the DAX with the nudge bar is a s**t idea, it would be so much easier if it wasn't there, i reckon now its more of a DAX gimmic to make you buy the "CUSTOM" rad from them for £300!!!!! thieving bast*rds!
i reckon i could solve the problem if i had an S-bend piece of hosing, 25mm ID,with a couple of inches of rubber each side of the s part! and it would save me loads of money in new bits!
anyone got anything that sounds like my descriotion lying around, long shot i know!
mcerd1
posted on 5/6/09 at 01:45 PM Reply With Quote
looks like something you'd need to weld / braze together....
do you know all the dimensions you'd want for this s bent thing ?
some people cut the nudge bar off
omega0684
posted on 5/6/09 at 01:51 PM Reply With Quote
i was seriously thinking about that!
i have found these elbows, i could use these with some 1" id radiator hose
posted on 5/6/09 at 02:39 PM Reply With Quote
your cat must have fat fingers as that linky no worky.
check out autoperformanceonline on ebay.
has 90 degre elbos that you can join up to make staggered pipe like you are after...... but you are looking at 25 mm ID so can you not use a length of straight hose or is the run too short to avoid kinking?
I don't see you mention how long this piece is - take a look at rover v8 water pump to manifold hose see GHC 709
I am not sure if it 25 mm thoughm think it is smaller - in fact I have some old one that I can post FOC - but I'd need to measure it first to see if it is of use. (NB old means usable but you'd want to replace should it prove to be successful).
----- looked at a ruler - pretty sure it is gonna be 5/8 inch i.e. too small.
BTW - don't quite understand what effect this has on your colling problem - you are thinking your current set up is restricting water flow?
[Edited on 5/6/09 by 02GF74]
posted on 5/6/09 at 02:46 PM Reply With Quote
yeah, two 90 degree copper pipe bends and some shrot lengths of pipe to join - check out B&Q.
you do mention length - I missed it - that Rover pipe is just the job then, if the ID is 25 mm.
forgot - that ebay seller has loads of 90 degree and straight reducers - no 45 deg reducers, in fact I have not seen that anywhere but then not really looked.
omega0684
posted on 5/6/09 at 02:47 PM Reply With Quote
linky worky now
posted on 5/6/09 at 02:51 PM Reply With Quote
linky worky now
sorry but those are shit*. very sharp bend plus plastic - I wouldn't use them on a hot water pressurised system - better off with copper plumbing bits if that is what you want to do.
* now waiting for someone to say they have used those successfully ..........
omega0684
posted on 5/6/09 at 03:42 PM Reply With Quote
i have used them successfully in the top half of my coolant system, they are fine
plus its gonna have to be a sharp bend other wise i can't get the pipes threw
