Author: Subject: OT - Rover 600 fuel pump location ?
mcerd1
posted on 9/6/09 at 01:25 PM Reply With Quote
any ideas ?
mcerd1
posted on 9/6/09 at 01:28 PM Reply With Quote
2 honda engine.
also where is the cut switch ?
Mr Whippy
posted on 9/6/09 at 01:29 PM Reply With Quote
in the fuel tank?
bilbo
It's in the tank. It was on mine anyway (620Ti), but could differ on other models I guess?
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
bilbo
posted on 9/6/09 at 01:30 PM Reply With Quote
IIRC the cut off switch is behind the dash in the ash tray area - but don't quote me on that?
mcerd1
posted on 9/6/09 at 02:30 PM Reply With Quote
cheers
posted on 9/6/09 at 04:03 PM Reply With Quote
Pump is in tank accessible through a hatch in the rear seat/boot area
Cut off switch is in the centre consol below the radio on the passenger's side it is bolted to to a zinc plated tubular steel reinforcing strut.
If it is no-starts when warm are usually down to a dry joint type failure of the soldered connections on the main relay.
With the Rover petrol engine non starts think crank sensors they tend to get iffy --- sometimes they just need taken out and cleaned . it is the wire breaking up.
If the failure to start is hot or cold then suspect the distributor ignition module on the Honda engine.
[Edited on 9/6/09 by britishtrident]
