omega0684
| posted on 10/6/09 at 05:23 PM |
radiator question
i have been looking at this radiator on ebay, it will fit in my nose cone and the core is 2893cm^3 more than my current rad. and its relatively
cheap!
as you can see from the picture the outlet is not at the bottom of the rad, what effect would this have on cooling, would it make the rows below the
outlet redundant? or would the rad be designed so the water passed threw the whole rad before exiting?
[Edited on 10/6/09 by omega0684]
dinosaurjuice
| posted on 10/6/09 at 05:32 PM |
on a forced/pumped system it doesnt make a massive difference. you may find that when idling only the top 3/4 are hot, but as soon as water pump
speeds up it will force water through all channels.
SteveWalker
| posted on 10/6/09 at 05:51 PM |
It is on the bottom if you rotate the radiator through ninety degrees
flak monkey
| posted on 10/6/09 at 06:06 PM |
I really do wish you would post in the right section sometimes.
It doesnt matter where the inlet and outlets are really. As Dinosaurjuice says on a pumped system it don't matter.
Sera
http://www.motosera.com
James
| posted on 10/6/09 at 06:19 PM |
You and your bloomin radiators!
What's wrong with a Polo like everyone else! Atleast we know that works!!!
Good luck sorting the problems!
James
- Muhammad Ali
MautoK
| posted on 10/6/09 at 06:22 PM |
Alex,
Is that a comparison of W*H*D overall or capacity?
2900 cm^3 is 2.9 litres (over 1/2 gallon) !
John.
quote: Originally posted by omega0684
... the core is 2900cm^3 more than my current rad....
[Edited on 10/6/09 by MautoK]
omega0684
| posted on 10/6/09 at 06:32 PM |
sorry john that is volume of the core and was supposed to read 2893 cm^3, yes its a big rad
my current core is 300x330x40, new core is 445x440x35
can't fit a polo rad as its too wide, i borrowed one off clairetoo,
so im thinking of cutting of the nudge bar at the front of the car and fitting this massive rad.
dave what is wrong with where the post is, we don't have a section for radiators.
flak monkey
| posted on 10/6/09 at 07:00 PM |
engine and transmission would be the obvious
Sera
omega0684
| posted on 10/6/09 at 07:05 PM |
the radiator isn't part of the engine or transmission, its separate
clairetoo
| posted on 10/6/09 at 07:17 PM |
Ahhh - thats where your problem is - on mine it's all connected
Its cuz I is blond , innit
Claire xx
Will weld for food......
Stuart_B
| posted on 10/6/09 at 07:26 PM |
i used a mk2 escort rad, as i could not get a polo rad to fit.
that looks like a nice rad, is it alu?
stuart
flak monkey
| posted on 10/6/09 at 07:34 PM |
Reply of the day
Sera
Staple balls
| posted on 10/6/09 at 07:42 PM |
omega0684
| posted on 10/6/09 at 07:51 PM |
HAHA,  , GOOD ONE
i guess i better connect it all up, but i really am debating getting the angle grinding out tomorrow and cutting the front nudge bar off. a few of the
other DAX guys have done it giving them bags of space up front, massive rads and oil coolers fitted
anyone want to buy my current rad? perfect for BEC application, will include a brand new rad switch too & a spare.
| posted on 10/6/09 at 08:11 PM |
the area alone, whcih IMO is better than depth - gives 1.9 times so should see you cool.
what is this nudge bar you refer to?
where will this new rad be fitted?
and will there be enough room.
I have mk2 escort rad FOC if you want it ... but it has plastic header hence would not bne possbile to sodler off the filler - you'd need a
solid radiator cap.
omega0684
| posted on 10/6/09 at 08:18 PM |
here is the nudge bar, thinking chop it off and then fit rad across the front of the chassis
MautoK
| posted on 10/6/09 at 10:55 PM |
Could do with one!
... we don't have a section for radiators.
