Nash
| posted on 1/7/09 at 05:51 PM |
Trouble with my Photo Archive
I uploaded two pictures to my archive last night and there appear to be in the archive but when I try to view them they won't open? It appears
the archive clicks through to photos but not my directory folder? Is it a site issue or is it me? Is antone else having a problem? Can anyone help?
cheers....Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
blakep82
| posted on 1/7/09 at 05:53 PM |
yeah, happens to me now and then. should be fine if you try a bit later
________________________
iank
| posted on 1/7/09 at 06:03 PM |
If it's the two with '+' signs I'm 99% sure that's the problem.
In your Mk Indy folder there is one with a + that doesn't work and one without that's fine.
Anonymous
mark chandler
| posted on 1/7/09 at 06:28 PM |
As above, the archive does not like special characters, ~$+ end the like, just use plain text and _ to sperate.
Nash
| posted on 1/7/09 at 07:07 PM |
Thanks both. It is the + that was causing the issues.
.......Neil
| posted on 1/7/09 at 07:20 PM |
Also - if the picture upload seems to run, but the file isn't there at the end, change the file name - it doesn't like it to be the same
as another picture anywhere in its database.
If you're trying to upload a jpg file, but it says that it's in the wrong format (which of course it isn't) it may be too big. For
this forum, 640 x 480 pixels is a good size.
Richard Quinn
| posted on 1/7/09 at 08:36 PM |
Hijack alert! I too have some pictures with file names that have picked up the odd % along the way but I can't seem to delete them. Is there any
way of doing this?
iank
| posted on 1/7/09 at 10:18 PM |
way of doing this?
The %20's are spaces that have been converted into url format.
If you can't delete them then I think you'll need to get an admin to do it for you directly in the file system - Don't know if
Fozzie can do that, so maybe you'll need ChrisW to do the deed.
Anonymous
