blakep82
| posted on 2/7/09 at 12:00 PM |
concreting
was laying some concrete yesterday, looks good, but i ran out of stones. now the layer i did yesterday should be fairly dry by now although it did
rain last night which i didn't expect...
am i going to come across problems pouring another layer on top today, on top of an already dry layer?
heavy rain is forcast about now too.... lol its 25 degrees outside. is it a bad idea to think about doing more? am i wasting my time thinking about
it? its only a small area, so easily covered til another day if i have to
its supposed to be the same level as the shed base
[Edited on 2/7/09 by blakep82]
________________________
minitici
| posted on 2/7/09 at 12:16 PM |
Concrete shouldn't 'dry' it should 'cure'.
You need to keep the curing concrete moist (cover with damp hessian sacks.
If it has 'dried' then the second pour may not take.
Perhaps you could use a PVA bonding agent but I'm no expert!
wilkingj
| posted on 2/7/09 at 12:19 PM |
Score some marks across the surface, to help the next layer to key in.
Cover it with wet sacks or cloth to stop it drying out too fast (goes brittle) especially in this heat.
Cover with polythene to stop the rain from washing off the cement layer and leaving you with a crappy surface (all stones exposed and nothing to hold
them down)
As you said its going to rain.
You could put a layer of wire mesh (from garden centre) to reinforce the thinner top layer when you pour the next part of the slab.
Or... lay paving slabs on top, with a lean mix bedding. (easiset I would think)
PS... I work in electronics, and am not a builder. Its just a few years of home improvements speaking!
Best Regards
Geoff
http://www.v8viento.co.uk
pgtips
When they concreted my yard two weeks ago ( 4 lorry loads and 6 inces deep) they where praying for rain otherwise they had to keep it wet with hoses.
I think if the concrete dry too fast witch it will with this kind of heat, then the concrete will crack.
I am not sure if you can poor another load of concrete to another allready set one with out ending up with two blocks of concrete???
If I die, my biggest fear is that my wife sells all my toys for the price I told her I bought them for...
blakep82
| posted on 2/7/09 at 12:23 PM |
well, withe the rain last night, i don't thnk its completely cured. maybe i'll just go for it. nothing to lose lol i'll ask at the
builders yard if it should be ok to pour on top again
| posted on 2/7/09 at 12:42 PM |
It would have been better to do it all in one layer rather than another thin layer on top but if it's not a heavy traffic area you should be
o.k. Concrete sets by a reaction which needs water and generates it's own heat so cover it with a sheet of plastic and leave it overnight. It
takes a couple of weeks to gain full strength.
blakep82
| posted on 2/7/09 at 01:29 PM |
the guy at the yard said it should be fine, so i'm going to crack on with the next bit. its about 3" it needs on top, so not too thin
Mr Whippy
| posted on 2/7/09 at 02:11 PM |
just wet the concrete before pouring the next, it'll take
my garage floor was poured just before a torential downpour and it did the surface a world of good gave me a very nice clean smooth but slighty
dimpled texture while washing all the scum away
woodster
| posted on 2/7/09 at 02:42 PM |
as said above concrete cures not dries a rough rule of thumb is at 25mm a day ..... and with respect yours is only carrying a shed
Vindi_andy
| posted on 2/7/09 at 02:47 PM |
As said before it will take weeks for the concrete to cure to an acceptable stage and can take months to fully cure depending on a number of
factors.
Im not sure if your thinking of any sort of finishing i.e. paint or resin but it should be left a couple of months before you do it
blakep82
| posted on 2/7/09 at 03:15 PM |
for a finish, i was just going to leave it a bit short of the top and then screed over the top.
i know its only carrying a shed (well, its a step to the shed...) but its been needing done for a while, my mum and dad are going away for a few
days and i wanted to get it done for them coming back. not told my dad i was doing it for him, so i didn't want it to be a disaster and fall
apart
zilspeed
| posted on 2/7/09 at 04:52 PM |
Anorak alert.
Concrete "hydrates"...
blakep82
| posted on 2/7/09 at 04:56 PM |
it does what now?
lol
whats the deal with this severe weather warning?! it said we'd have 8mm between 1pm and 4pm, and 9mm between 4 and 7. there's been nothing
at all so far!
woodster
| posted on 3/7/09 at 09:19 AM |
thats because concreting is a science where weather forcasting is just guess work
