Author: Subject: Celica gt4 questions
turbodisplay
posted on 2/7/09 at 10:06 PM Reply With Quote
Hi, might be a long shot........
Bought a 1990 celica gt4 St185, 200hp 4x4.
It needs a new gearbox, does anyone know if the newer model (st205) gearbox will fit?
Also will the abs ecu from the newer version fit?
Thanls
Darren
eccsmk
posted on 2/7/09 at 10:26 PM Reply With Quote
i seem to remember the gearboxes being different but im not 100% sure
cant help with the abs ecu tho
might be worth checking with these people prob best to phone
HTH
gaz_gaz
posted on 2/7/09 at 11:32 PM Reply With Quote
the gearbox from a st205 will fit in the 185.
you just need to swap the speed sensor from your gearbox over.
the abs ecu's are not common between models, im sure they have diff plugs for starters
i can get hold of both boxes,
150 for st185
250 for st205
also
40 for st185 abs ecu
Gary
[Edited on 2/7/09 by gaz_gaz]
turbodisplay
posted on 3/7/09 at 01:08 PM Reply With Quote
Cheers for the replies.
Gaz-gaz, do you have a rear diff from a ST205? if so how much?
The abs ecu does work on my car, but i was just wondering if the later ecu will allow more slip, as i find i have to be very progrssive on the brake or the abs cuts in early.
Darren
gaz_gaz
posted on 3/7/09 at 07:49 PM Reply With Quote
Hi mate,
rear diff would be about 100 quid.
Gary
