Author: Subject: plumbing question!
jlparsons
posted on 9/7/09 at 08:54 PM Reply With Quote
plumbing question!
Ok not car related, but I knew you lot would come up with a quick answer when I need it!
I'm round my mates house tonight and helping with a bit of plumbing. I've always used soldered copper, never used pushfit or plastic - his flat is new and a mix of copper and plastic pushfit.
Can a copper compression joint be placed over 15mm plastic pipe? Or will it crack or leak?
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
eccsmk
posted on 9/7/09 at 09:01 PM Reply With Quote
it can providing you use the correct insert
if the pipe is the grey stuff use a steel insert
if the pipe is white use a solid plastic insert
as a general rule that is
HTH
these are the ones they dont have the rubber seals on them
[Edited on 9/7/09 by eccsmk]
mookaloid
I don't believe so.
Even if you are using push fit joints you need to have special inserts to push inside the pipe to stop it collapsing and leaking, so I don't think it will work with a regular compression joint.
jlparsons
posted on 9/7/09 at 09:23 PM Reply With Quote
Brilliant, thanks guys. Reliable as ever!
As an afterthought, we have a plastic compression joint. I assume this will join to copper pipe without a problem? I'm guessing the normal ptfe tape will do to seal it?
Cheers!
eccsmk
posted on 9/7/09 at 09:26 PM Reply With Quote
4 x wraps of ptfe on the olive only!!!!!
this should do the trick
posted on 9/7/09 at 09:33 PM Reply With Quote
never seen a plastic compression fitting, do you mean a push fit?
eccsmk
posted on 9/7/09 at 09:34 PM Reply With Quote
somehow i read it wrong
i think you may well be correct
jlparsons
posted on 9/7/09 at 10:07 PM Reply With Quote
Brilliant, cheers guys. Job done.
