omega0684
| posted on 13/7/09 at 01:00 PM |
Frontera Question
a mate of mine is having trouble with his frontera, i know whats wrong but don't know what the part is called that he needs to replacement, so i
call on locostbuilders to try and find the answer.
the part that needs replacement only appears to be on the petrol models (my mate has the 2.2 ecotec petrol) the sensors position is on the left side
of the engine bay as you open the bonnet, its behind the airbox and has vac pipes leading into it from the inlet manifold and the fuel pressure
regulator.
the sensor is positioned on the side of a unit that has a two pipes leading into it, one from the exhaust manifold and the other from the
airbox(engine side of the filter) the unit loks like it has some sort of actuator on the top which has a vac pipe going to hte sensor as well.
anyone know what it is? MAP sensor perhaps?
[Edited on 13/7/09 by omega0684]
rayward
| posted on 13/7/09 at 01:04 PM |
maybe the EGR (exhaust gas recycling?) valve
hth
Ray
omega0684
| posted on 13/7/09 at 01:06 PM |
it has an electrical connection on it as well so im guessing it has some input back to the ecu
omega0684
| posted on 13/7/09 at 01:12 PM |
RAY YOUR A LEGEND!
rayward
| posted on 13/7/09 at 01:14 PM |
like this...........
omega0684
| posted on 13/7/09 at 01:34 PM |
no, its the solenoid valve on the side that im after, i found it in the haynes manual, just got to find a replacement now!
Gazeddy
| posted on 13/7/09 at 07:30 PM |
is it not an oxygen injector system. ford fitted them to clean up the emissions
