Author: Subject: Help on brake cap with symbol?
AdrianH
posted on 23/7/09 at 10:43 PM Reply With Quote
I have the typical Sierra brake reservoir This type with the yellow cap in the centre.
brakecap
brakecap
I am trying to discover if there is a Ford centre cap that has the brake fluid symbol on the yellow bit to remove one of the jobs for IVA.
Perhaps another cap may fit I am just not sure, say the mk3 Mondeo one would fit?
I have searched ebay for potential answers looking through the car parts etc. Does anyone know what may do?
Adrian
[Edited on 23-7-09 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
austin man
posted on 23/7/09 at 10:58 PM Reply With Quote
draw it on with a cd marker pen. or have a local graphics company print you a sticker
dave-69isit
posted on 23/7/09 at 11:31 PM Reply With Quote
get to the scrappy rovers had them on the 2oo 4000 600 just pop over the threads on cap
jack_t
posted on 23/7/09 at 11:41 PM Reply With Quote
we didnt need the symbol on it for Sva
blakep82
posted on 24/7/09 at 12:23 AM Reply With Quote
can't find any requirement for having a brake symbol marked on it (theres not even a requirement for a brake fluid warning light)
15.
A fluid reservoir cap must be present and secure.
16.
It must be possible to check the fluid relative to the manufacturer’s specified minimum level on all brake fluid reservoirs by the actual fluid level being visible through a transparent section of the reservoir, with the minimum level marked permanently on to this section. As an alternative, a red warning lamp (see figure 3) must be capable of illuminating
________________________
Mix
posted on 24/7/09 at 12:44 AM Reply With Quote
Hi
Read on .........
17.
The type of fluid to be used in the hydraulic transmission of braking systems must be identified in accordance with ISO standard 9128-1987. The relevant symbol according to Figure 1 or 2 must be affixed in a visible position in indelible form within 100 mm of the filling ports of the fluid reservoirs, additional information may be provided by the manufacturer.
Regards Mick
[Edited on 24/7/09 by Mix]
Mix
posted on 24/7/09 at 12:49 AM Reply With Quote
And .........
19. The hydraulic system must be fitted with a red warning lamp, sensitive to line pressure and capable of signalling the failure of any part of the hydraulic system as soon as the brake is applied and remaining lit as long as the failure exists (with the ignition switched on). As an alternative, the warning lamp must be sensitive to the reservoir fluid level, providing the reservoir is directly connected to supply the pressure side of the master cylinder when the piston is in the “brakes off” position, so that a failure of either part of a split system would result in a continuous draining of the reservoir fluid when the control is released (see note 2 and 3).
20.
The hydraulic system failure warning lamp must be secure, operational, visible during daylight and darkness from the driving position, identifiable (i.e. labelled in a recognised form – see diagram 1 for an example) and fitted with a “test facility” that enables its operation to be checked from the driving position without opening the reservoir.
Regards Mick
blakep82
posted on 24/7/09 at 12:52 AM Reply With Quote
my mistake
Macbeast
posted on 24/7/09 at 07:13 AM Reply With Quote
There's a marketing opportunity for someone to produce decals for brake reservoir, brake fluid etc
AdrianH
posted on 24/7/09 at 07:21 AM Reply With Quote
Limited market but a market, I will have to check rover and other caps ASAP.
Adrian
mistergrumpy
posted on 24/7/09 at 09:19 AM Reply With Quote
Car Builder Solutions here. Just stick it to the bulkhead within 100mm of the reservoir cap.
ashg
posted on 24/7/09 at 12:27 PM Reply With Quote
cbs didnt hang around getting those in.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
iank
posted on 24/7/09 at 01:18 PM Reply With Quote
I've just put a pdf on the IVA section (can't post attachments in this section) which I hope should be useful to anyone who want's to DIY their reservoir cap marking.
http://www.locostbuilders.co.uk/viewthread.php?tid=118178
Anonymous
jollygreengiant
posted on 24/7/09 at 03:29 PM Reply With Quote
Originally posted by Mix
And .........
20.
Regards Mick
The way I read that, is that you would need TWO in line pressure switches in your IVA brake system (diagonal split being required now I believe) as well as the fluid level switch as it is possible to have a failure mode where pressure is lost but not fluid. (Vauxall master cylinder reversed seal syndrome).
iank
posted on 24/7/09 at 03:34 PM Reply With Quote
And .........
20.
Regards Mick
Diagonal split is NOT required, despite what one of the magazines read the rules to mean.
See minitici's post in this thread.
http://www.locostbuilders.co.uk/viewthread.php?tid=91800
Anonymous
AdrianH
posted on 24/7/09 at 06:32 PM Reply With Quote
Thanks for the posts and ideas
