eccsmk
| posted on 29/7/09 at 03:48 PM |
evo 6 info and help
a good friend of mine has just baught an evo 6
which has got a strange starting problem
it takes alot of turning over before it starts but once started it runs really well
also does anyone have any info about wallace performance ?
rumour has it this car has been to them
thanks folks
| posted on 29/7/09 at 03:54 PM |
raised compression causing the starter to work harder?
Knackered starter?
Worn rings needing time to get upto compression?
Lumpy cam/ecu map?
eccsmk
| posted on 29/7/09 at 04:02 PM |
oh dear it looks bad
compression check is being done tonight
starter is fine
AFAIK compression is standard (so he told me this morning)
omega 24 v6
wallace performance in Aberdeen???????
Here?
Could be a host of things.
Maybe
Lack of fuel pressure
Fuel vaporization after stopping/while standing
[Edited on 29/7/09 by omega 24 v6]
eccsmk
| posted on 29/7/09 at 04:12 PM |
cheers for the linky
ill have some more info tomorrow or late tonight as hes going to take me for a spin in the olde bus
i might even be tempted to sell the indy and get one myself
GeorgeM
| posted on 29/7/09 at 04:13 PM |
not just a bad earth is it?
GeorgeM
eccsmk
| posted on 29/7/09 at 04:33 PM |
it could well be
i will have to see later on
(i can see me getting frustrated at not being able to help out)
i will post my findings on here later on
thank you
mark chandler
| posted on 29/7/09 at 07:12 PM |
Something simple maybe, engine temp sensor?
If this goes it will be an absolute pig to start when cold
eccsmk
| posted on 29/7/09 at 09:01 PM |
well we have kind of located the fault and its a bit more serious than first thought
so the engine is coming out
