Author: Subject: Pipework below ground
wicket
posted on 3/8/09 at 10:34 AM Reply With Quote
I'm trying to locate a storm water drain below a concrete path. I don't really want to break up to much concrete, is there a clever DIY way of finding it?
mookaloid
posted on 3/8/09 at 10:49 AM Reply With Quote
Divining?
Dowsers Linky get your self a couple of coathangers
balidey
posted on 3/8/09 at 10:53 AM Reply With Quote
can you get site plans or drawings?
Mr Whippy
posted on 3/8/09 at 10:54 AM Reply With Quote
Divining?
strangely it appears to work from experience
found and traced the route of an asbestos water main across 4 acres of land after digging in the wrong place for several hours and once it had been dowsed for found it directly under the ‘located’ route almost 2m down all a bit weird really
have to say I pi$$ed myself laughing too when it was suggested but had to eat my own words when it was found with two bent welding rods!
[Edited on 3/8/09 by Mr Whippy]
blakep82
if you know where an opening for the drain is, stick a hose down it, then listen with a stethescope type thing?
________________________
Mr G
posted on 3/8/09 at 11:33 AM Reply With Quote
Get quotes from local builders to install a new drain to hook up with the stormwater drain.
They need to locate its position to give you the quote
G
theconrodkid
posted on 3/8/09 at 11:52 AM Reply With Quote
another vote for divining,stainless steel rods work the best,now someone will tell us how it works
who cares who wins
pass the pork pies
Guinness
posted on 3/8/09 at 02:45 PM Reply With Quote
G
Bad form to waste a builders time IMHO.
Far better to get a kitten / small dog / child, send them down the nearest manhole and then call the fire brigade.
Mike
