Author: Subject: trying to trace a vibration
:{THC}:YosamiteSam
posted on 3/8/09 at 08:37 PM Reply With Quote
im getting a bad vibration from my megabusa
when on track going over 100mph is nigh impossible due to the vibrations
i still have to get the wheels double checked for balance - if its those - rear - front isnt transmitting thro the steering
feels like the rear end through the floor or possibly propshaft - transmission
1 question - iv noticed play in the gearbox output shaft - if you rotate the flange by hand how much free play is normal?
my own feeling is prop balance or wheel bearing / wheel balance.. just going through the cheapest, quickest and easy options first
any ideas?
Guinness
posted on 3/8/09 at 08:43 PM Reply With Quote
Can you get easy access to the propshaft / driveshafts?
Someone mentioned using jubilee clips as balance weights?
Mike
:{THC}:YosamiteSam
posted on 3/8/09 at 08:47 PM Reply With Quote
Mike
yea - easy to get at most things but how would you know where to put the weight? - thats a real critical thing to get wrong!
MakeEverything
posted on 3/8/09 at 08:54 PM Reply With Quote
Check your tyre pressures. Youll be surprised at the difference this makes.
Kindest Regards,
Richard.
eznfrank
posted on 3/8/09 at 08:59 PM Reply With Quote
Are you running a reverse box?
r1bob
posted on 3/8/09 at 09:11 PM Reply With Quote
also check your prop alignment, first half of prop from gearbox should be square off the gear box flange (90degree's horizontal looking sideway's and 90 degree's looking down at it off flange) if it is in 2 halves ,the rear half can go off at an angle to the diff,
the gear box flange should have minimal up and down play.
had 2 prop's overhauled for me in the last 6 month's for myself and a mate, cost around £50 each including new splines and balancing,so not the end of the world
:{THC}:YosamiteSam
posted on 3/8/09 at 09:21 PM Reply With Quote
and this would put them out of balance? they would have to rotate on the rim to do so - i run the front at 14psi - rear 16psi dont think they have slipped round the rim but as i say thats my next call - also have a small grease gun - going to re grease prop joints
yea - westfields own - i know its not the best and it is the most expensive - i would love to change to an electric reverse tbh but cash isnt fluid.. lol
i havnt noticed any up and down movement but did wonder about output shaft possible wear - without knowing what other busa freeplay is i wouldnt know - probably around 5-10mm play i have
i do have a diff output seal (lhs) with an oil leak but the diff is fully loaded - i wonder if the bearing is on its way - leaking thro that.. testing just give it a good 'yark' lol - see if it moves up n down or rattles... lol??????
posted on 3/8/09 at 09:34 PM Reply With Quote
Mike
I'd be very surprised if a jubilee clip in the wrong place is that critical.
find track or stretch of road and drive car at certain rpm and speed.
fit clip, and compare with above.
if better, job done.
if same the problem lies elsewhere.
if worse, rotate clip 180 degrees and repeat.
obviously you would not drive at same speed if the vibration is really bad so there is some common sense involved - hence why I said the fitment is not critical .... no doubt someone will come along and prove me wrong, which is fine since this is my theory as opposed to anything I have tried.
MakeEverything
posted on 3/8/09 at 09:37 PM Reply With Quote
Generally, tyres dont rotate around the rim, but if the pressures are different particularly each side it will affect the harmonics of the car, cause vibration, and pull to one side - including under braking.
When the tyre pressures are lower than designed, the tyres respond in differing ways causing them to re-form or mis shape slightly which would cause the vibration that you mention.
Kindest Regards,
Richard.
austin man
posted on 3/8/09 at 09:44 PM Reply With Quote
I once hasd a tyre that was twisted that really caused a bad vibration, play in the input shaft could be a cause, as could the diff or prop. Have you had the wheels off recently ?? I have also come across a problem with the wheel not sitting on the hub flat due to rust or a dirt at the rear of the wheel.
:{THC}:YosamiteSam
posted on 3/8/09 at 10:12 PM Reply With Quote
Mike
no disrespect but a prop spinning that close to my hips / legs and passengers isnt getting a jubillee clip on - a prop not balanced correctly is a lethal weapon - it should be ONLY done right - by people who have the right gear - no other way.
i would guess its gotta come off and be measured
:{THC}:YosamiteSam
posted on 3/8/09 at 10:15 PM Reply With Quote
tyres can slip on the rim due to the soap used during mounting the tyre on
famous example is the mansell vs prost british GP where he had to pull in due to tyre balance being that bad - he braked hard the grip slipped the tyre round the rim
we use at work a test for that - a simple painted yellow dot on the tyre - a red dot on the rim - it has to be within 35mm of each other after testing otherwise weight position goes out
r1bob
posted on 3/8/09 at 10:16 PM Reply With Quote
you always get a bit of back lash,rocking the prop to and throw, but you should have minimal up and down movement where they go into the bushes, if you have, the spigots could be worn or the bushes, alot of up and down movement will cause bad vibration,,,, double check prop alignment as this can be critical as i found out.
:{THC}:YosamiteSam
posted on 3/8/09 at 10:17 PM Reply With Quote
yes i have had the wheels off too - theres no dirt or rust but it wont hurt to relook and make sure
when i take the tyres down to be rebalance checked i want to watch the tyre spin
you cant check it on the car because there might be bent suspension parts
:{THC}:YosamiteSam
posted on 3/8/09 at 10:23 PM Reply With Quote
yea - will look at that - what a loverly place to try and get at tho - lol - luckily the top tunnel cover is just bolted down
i need to remove it to regrease the uj's
if i had to put money on it it feels like tyre distortion or balance
miikae
posted on 3/8/09 at 10:34 PM Reply With Quote
If you feel it may be tyres just check that there is no water in them due to bad air line water filters , i had this problem a while ago , it was only discovered when as a last resort they took the tyres off the rims.
Mike
If it can be done it i will be done .
Russ-Turner
posted on 4/8/09 at 06:20 AM Reply With Quote
Mike
mad4x4
posted on 4/8/09 at 09:13 AM Reply With Quote
Mike
My prop was out of balance and destroyed the Engine Mounts and cracked the bell housing and tore off one of the engine block lugs. ..... (all in about 18miles)
And that was all due to vibration only luckily Prop stayed put. EnDed up buying a New Prop that was true balanced.
Scot's do it better in Kilts.
SJL
posted on 4/8/09 at 09:18 AM Reply With Quote
You need to find a tyre shop with a Road Force balancing type machine.
We have one at work and rather than just balancing the wheel/tyre it applies a measured load to the tyre and tells you if the tyre is any good.
Even when we have fitted new tyres this machine has found faults,it then allows you to correct this by trying to match the tyre to the rim.
Its from these people http://www.beissbarth.co.uk/ so it might be worth giving them a call and seeing if they have supplied one to someone local to you.
I have to be honest though its probably the reverse box as everything I have read about them indicates they have problems
:{THC}:YosamiteSam
posted on 4/8/09 at 10:09 AM Reply With Quote
i could well believe that but wow that must of been a long way out.. props really can be underestimated to the damage they can do.
:{THC}:YosamiteSam
posted on 5/8/09 at 07:20 AM Reply With Quote
think i might of sussed it.. The reverse box.. The 2 sets of prop bolts were loose.. Finger tight.! Just got to test it to see what its like..
:{THC}:YosamiteSam
posted on 9/8/09 at 09:28 PM Reply With Quote
well i stripped it down.. Again.. Reverse box drive flange nut was loose on both sides of the box.. Got about 1 turn on the nut.. Just need to finish rebuilding and give a test.. Fingers crossed..
