Author: Subject: rally argentina - with a difference
:{THC}:YosamiteSam
posted on 19/8/09 at 02:23 AM Reply With Quote
rally argentina
speedyxjs
posted on 19/8/09 at 06:03 AM Reply With Quote
Cool!
omega0684
posted on 19/8/09 at 07:09 AM Reply With Quote
RK
posted on 19/8/09 at 01:24 PM Reply With Quote
Affordable motor racing. Amazing.
ken555
posted on 19/8/09 at 08:10 PM Reply With Quote
Could you build one for £250 ?
:{THC}:YosamiteSam
posted on 20/8/09 at 01:48 AM Reply With Quote
these tracks are quite easy to make
using mdf for a base
then draw out your groove
use a router with a slot cutter
then use foil tape (the kind used for alarms on windows) there are other types - for the contacts
you can send the car anywhere you want
i made a track years back if you do it right you can have some wild drifts - the scalextric cars fall off usually because the track is too narrow - widening the track letting the rear end slide out stops it just about (unless you come in too hot)
use blackboard paint for the track surface - after a while the tyres start leaving rubber on the track too looks kinda cool
i have a pc program some where that controls the racing
there are also some systems now which use cars on the same track! using the old hornby theory with a chip in the car as in the Zero 1 system they had. so you can have 2 cars same track - 2 different speeds
or there is this -
slotfire
