speedyxjs
posted on 22/8/09 at 05:00 PM |
Doh
When to fit the clutch cilynder onto the bellhousing today and dropped the pin that acts on the clutch fork into the bellhousing
Engine out tomorrow then
mark chandler
| posted on 22/8/09 at 05:04 PM |
Magnet on a bit of string, everything else is ali so should do the job.
pewe
| posted on 22/8/09 at 05:11 PM |
Buy one of those pen size extending magnetic pick-up tools from Toolstation, B&Q, Screwfix etc. etc.
Even drill a hole in the lower edge of the bell-housing to access before you start stripping the box off.
BOL.
Cheers, Pewe
minitici
| posted on 22/8/09 at 06:38 PM |
I feel your pain!
I once dropped the dizzy drive gear of a Mini engine into the depths of the gearbox.
It was a 8 hour engine out and strip job from the rear of my GTM
speedyxjs
| posted on 22/8/09 at 07:34 PM |
I tried that but it just kept clinging to the flywheel
mark chandler
| posted on 22/8/09 at 07:54 PM |
As above then, I have one of those extending magnets on a stick, actually like a small car aerial and its very useful for probing as you can steer
clear of other stuff.
Worth a couple of quid even if it does not work in this instance.
speedyxjs
| posted on 22/8/09 at 07:57 PM |
^^^ tied that too but there isnt enough room to get it at an angle that avoids the flywheel.
dmac
| posted on 22/8/09 at 08:40 PM |
Is the bell housing on studs or bolts? Can you slacken the nuts/bolts enough to leave a gap for the pin to fall out? If it is on bolts. replace a few
with threaded rod to give more movement.
Duncan
speedyxjs
| posted on 22/8/09 at 08:44 PM |
Duncan
I couldnt get the gearbox back far enough to open up a big enough gap.
owelly
| posted on 22/8/09 at 09:04 PM |
Just shake the car upside down. Some of you guys are really stupid.......
http://www.ppcmag.co.uk
speedyxjs
| posted on 23/8/09 at 11:54 AM |
Got it out now. Managed to yank the engine forward enough to get my fingers in the bell housing. Turns out its made of brass thats why i couldnt get
it with the magnet
| posted on 23/8/09 at 12:10 PM |
quote: Originally posted by minitici
I feel your pain!
Been there, done that! Fortunately managed to retrieve it after fishing around with a strong magnet on a stick for about an hour.
