m8kwr
| posted on 7/9/09 at 11:00 AM |
Any gas engineer people on here
I am having a wood burner installed, and i fetched the old fire surround off yesterday and found a gas pipe end to fit a gas fire to.
I have no idea if there is gas flowing? (i have an electric fire at the moment)
Is there any way that i could check, without calling out a gas engineer - something like poking it with something and then try and smell if gas comes
out!!!!!
Also if it is live, is there any issue with having a wood burner quite close to it? I assume not, nut thought i would ask.
| posted on 7/9/09 at 11:08 AM |
Does it look like these?
http://www.bes.co.uk/products/006.asp
m8kwr
| posted on 7/9/09 at 11:14 AM |
Yes -probably more like the second one, but without the nut.
I did fetch the screw off the top, but could not smell anything....
m8kwr
| posted on 7/9/09 at 11:17 AM |
Could i just push a small screwdriver up, to open the flow, and see if i can smell gas coming out, and hear it...
If i can't, then i can get my Mr Grinder out
mookaloid
| posted on 7/9/09 at 11:22 AM |
The screw on the top is only a cover. There should be a second screw inside which isolates the gas.
Thought it was worth mentioning before you get Mr Angry Grinder out!!!!
Good luck with your exploding
| posted on 7/9/09 at 11:34 AM |
Who's got some popcorn?
mookaloid
| posted on 7/9/09 at 12:09 PM |
liam.mccaffrey
| posted on 7/9/09 at 12:51 PM |
I've only ever met one gas engineer and he didn't install or repair domestic heating systems for a living Plumbers are not
engineers. If you think they are you should read the required competencies the IMechE stipulate for membership.
I believe the term engineer should be protected like Dr, and in case anyone asks I'm not an engineer yet, but I'm working on it!
Saucer of milk for one please.
[Edited on 7/9/09 by liam.mccaffrey]
Build Blog
Build Photo Album
mistergrumpy
| posted on 7/9/09 at 01:01 PM |
I agree. Too many people claiming that title. It's for the clever deserved people only.
A bit like the title "chef". Not unless you've a degree in cheffery are you a chef!
big-vee-twin
| posted on 7/9/09 at 01:02 PM |
As a fully qualified engineer, following the above guidance, I would recommend you have a gas fitter sort it out for you.
You dont want to be sitting in a pile of ashes when you light your wood burner do you.
By the way you will need a flue that can be used with a wood burner and not the one that is probabily left from the gas fire, or flue liner if there
isnt one installed as it will have to deal with different emmisions - wood has higher water content and can corrode a standard flue.
http://www.triangleltd.com
big-vee-twin
| posted on 7/9/09 at 01:04 PM |
Oh buy the way obtaining a degree doesn't make you an engineer.
A Masters degree and 5 years experience makes you an engineer and then you get letters like these to put after your name - CEng which means Chartered
Engineer.
[Edited on 7/9/09 by big-vee-twin]
mookaloid
| posted on 7/9/09 at 01:28 PM |
I always thought that an engineer was a person who worked on the tools...whatever the trade
Whereas an Engineer was the one with the Degree and the Chartered Engineering status..
I could be mistaken
chrsgrain
| posted on 7/9/09 at 02:08 PM |
quote: Originally posted by liam.mccaffrey
I believe the term engineer should be protected like Dr...
Unfortunatley 'Dr' isn't a protected term at all - hence charlatans like "Dr" Gillian McKeith and a whole host of other
people who neither have a PhD or a medical degree....
Next time you go to hospital, make sure the person you see is a 'registered medical practitioner' (and ask what their GMC number is), that
term is protected by law, then you won't be seen by a fake "doctor"....
Chris
Large saucer of milk here please!!
cd.thomson
| posted on 7/9/09 at 02:10 PM |
Chris, what hospitals employ "Drs" not registered with the GMC...
Oh yeah, I know, the Royal Homeopathy Hospital
Craig
chrsgrain
| posted on 7/9/09 at 02:16 PM |
Apart from that one - lots and lots, I would guess most hospitals in the UK have people who call themselves 'Dr' working there without GMC
registration or a medical degree.... the vast majority will have a PhD, and I have no problem with them calling themselves 'Dr'. BUT they
should be damn sure that any patients know that they are not medical doctors, nor registered with the GMC.... its becoming more of a problem with
fuzzy job titles like 'consultant practitioner' (who generally aren't Doctors)......
Chris
