Author: Subject: Fuel strainer material
bigandy
posted on 16/9/09 at 01:04 PM Reply With Quote
Afternoon all.
Does anyone know where I might be able to source some of that material that is used on the pickup for in-tank fuel pumps at all? It is usually white when new, and is about 1mm thick, and is sort of spotty/dimpled and usually heat sealed in the shape of a bag? It is NOT the nylon mesh type stuff, but is more like a felt type material...
I'm after some for another application, but can't find anywhere that can supply it not already formed into fuel strainers for in tank pumps...
Any ideas anyone?
Dammit! Too many decisions....
bigandy
posted on 16/9/09 at 01:06 PM Reply With Quote
I forgot the image, it is the material used on parts like this:
http://www.autopartswarehouse.com/sku/Delphi/Fuel_Strainer/DPFS0099.html?tlc=Engine+%26+Drivetrain
posted on 16/9/09 at 02:19 PM Reply With Quote
I don't know what you are referring to as linky does not work for me.
Brass mesh and soldering iron is all you need to make a strainer to whatever size and shape you want, within reason - that is how I did it.
now getting hold of the brass mesh, that is another story.
miikae
posted on 16/9/09 at 02:27 PM Reply With Quote
Brass mesh can be found on ebay.
Mike
If it can be done it i will be done .
bigandy
posted on 16/9/09 at 02:39 PM Reply With Quote
The material I am after is NOT a mesh type of any sort. It is like a felt type fabric. It is more of a filter than a strainer, and apparently it is commonly used on the in-tank fuel pumps...
