blakep82
| posted on 29/9/09 at 12:41 AM |
keeping rubber soft
found out why my car runs like a bag of shit. part of the air intake (after the airflow meter) is all split.
i found a replacement i can have tomorrow, but it looks a little like its already starting to split. is there anything i can use on it to keep it soft
and flexible to buy some more time out of it?
________________________
Ben_Copeland
| posted on 29/9/09 at 07:13 AM |
Something like this might work ok?
303 Aerospace Protectant
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
graememk
| posted on 29/9/09 at 07:29 AM |
push bike tyre inertube over it should seal it.
40inches
| posted on 29/9/09 at 07:46 AM |
I use plumbers silicon oil, used to lubricate push on plastic fittings, you can buy it at Wickes. Used it to rescue the Targa roof seals on my sons
MR2 Turbo, worked like a charm, no more leaks. Paint it on the rubber and allow to soak in, heat helps so no problem with engine bay heat.
http://www.wickes.co.uk/Silicone-Lubricant/invt/432013
Should be able to get it at any plumbers merchant.
blakep82
| posted on 29/9/09 at 11:07 AM |
awesome, cheers guys think silicon oil is the way to go. will check it out.
graeme, its about 80mm diameter i think, and got several other pipes going into it, so not sure that would work. thanks anyway
i'll get a photo up of the old pipe in a sec. i can't believe how bad it was!
blakep82
| posted on 29/9/09 at 01:03 PM |
yeah, this was the original
don't know how i never noticed it before
