Author: Subject: OT: Trailer help
matt.c
posted on 24/10/09 at 07:24 PM Reply With Quote
OT: Trailer help
I have bought one of these small tipping trailers but when it is tilted fully it doesnt have any type of locking devise to keep it up. Have looked and have found the props for the rear of the trailers but nothing to hold the front up. Any idea's guys and girls?
dinosaurjuice
posted on 24/10/09 at 07:30 PM Reply With Quote
a stick
designer
posted on 24/10/09 at 07:31 PM Reply With Quote
The weight of the contents is supposed to do it.
RichardK
posted on 24/10/09 at 07:44 PM Reply With Quote
Wonder if something like a small bottle jack could be modified in some way to jack up the back.
Seems strange that it doesn't have some method of tilting though as standard.
Rich
Gallery updated 11/01/2011
jacko
posted on 24/10/09 at 07:53 PM Reply With Quote
How about a post with a winch on the top welded to the towing part of the trailer then the cable attached to the body
matt.c
posted on 24/10/09 at 08:24 PM Reply With Quote
Originally posted by dinosaurjuice
a stick
Urm. Its going to have a kart mounted on it!
Needs to hold the trailer up but i need to be able to control it dropping back down.
trextr7monkey
posted on 24/10/09 at 08:59 PM Reply With Quote
Some kind of big ram like on engine cranes - got a similar thing here fitted to a lifting arm on a pivot - imagine the kind of thing they use for lowering invalids into swimming pools, has remote jack with long length of hydraulic pipe so could be controlled from behind trailer etc
Bought it with the intention of fastening on to trailer draw bar to load engines in when there's no engine crane about but like many great projects it is still sitting there.
Doesn't stand us at lots of cash but heavy to post and we are in Cumbria but could produce a substantial solution to your problem, I'd send pics but it is blowing a gale out there tonight
atb
Mike
Edited to add- there are pics of it somewhere in the archives linked below if anyone is curious
[Edited on 24/10/09 by trextr7monkey]
miikae
posted on 24/10/09 at 09:11 PM Reply With Quote
How about a caravan type jockey wheel jack fitted to the trailer top bar, wheel removed and the y joke pinned to the draw bar, you could then wind the trailer up and when done wind it down to lock it.
Just one of my KISS thoughts
Mike
[Edited on 24-10-2009 by miikae]
If it can be done it i will be done .
austin man
posted on 24/10/09 at 09:29 PM Reply With Quote
just use the red arrow seems to be doing a good job LOL.
Mount a bottle jack or a scissor jack to the frame and body
Richard Quinn
posted on 25/10/09 at 08:03 AM Reply With Quote
Are you just planning on tipping your kart off or are you trying to tilt it enough to drive it on
Personally, I would avoid using the tilty function on that type of trailer. The pin not going back in properly or being forgotten altogether would be too big a risk for me. Just get someone to give you a hand to lift the kart on and off without tilting
Danozeman
posted on 25/10/09 at 09:33 AM Reply With Quote
If you can tip it yourself id put one of the props for the rear on the front.
Or one of these
The you can tilt it with that thus saving your back!
Dan
owelly
posted on 25/10/09 at 09:38 PM Reply With Quote
For a cheaper version of those 'Side Winder' jacks, go to an autojumble as most old cars used them as the standard change-a-wheel jack!
http://www.ppcmag.co.uk
jacko
posted on 25/10/09 at 10:11 PM Reply With Quote
Scissor jack just in front of the pivot point with a long Handel to the front
