Author: Subject: Garage door seal
bigbravedave
posted on 30/11/09 at 12:34 PM Reply With Quote
Garage door seal
What do people recommend for sealing that ¼” gap between the bottom of a garage door and a concrete floor, the commercially available seals bond to the concrete floor so its only a matter of time before I drag something through it. I want something that I can attach to the up and over door, was thinking brush seal but I cant see it stopping water trying to come in when the heavens open.
andrew-theasby
posted on 30/11/09 at 12:38 PM Reply With Quote
I put a thick bead of sealant on the bottom of the door then a strip of polythene over it, shut the door so it squeezed out then peeled the polythene off when it had set and trimmed it up. Certainly stops the rain blowing under as much.
James
posted on 30/11/09 at 12:43 PM Reply With Quote
For a few quid on Screwfix you can buy a kit with a rubber strip.
You're never gonna create a fully watertight seal... but it'll help!
James
Mr Whippy
posted on 30/11/09 at 12:46 PM Reply With Quote
do what i did and simply put a piece of wood along the bottom, then get a small bag of water proof fast setting cement. Then from the inside of the garage out to the wood make a shallow ramp so once the woods removed there is a small step (15mm is fine) that is just behind the back of the door. That will stop any rain entering.
miikae
posted on 30/11/09 at 12:48 PM Reply With Quote
My garage door is a metal one and it has a central slot in the botton which i fitted a length of hose pipe in to form a seal with the floor, it works well and cheap too.
Mike
If it can be done it i will be done .
liam.mccaffrey
posted on 30/11/09 at 01:03 PM Reply With Quote
I actually cast a door recess into the floor of the garage to stop this. My door also has an integral weatherstrip.
The last garage I had was terrible for water coming in. it was built on a downslope so when it rained the water just ran down the drive and under the door. I dug a catch drain right across the width of the drive in the end. That sorted it.
[Edited on 30/11/09 by liam.mccaffrey]
Build Blog
Build Photo Album
Mr Whippy
posted on 30/11/09 at 02:54 PM Reply With Quote
you can buy this which will seal stop rain entering
linky
posted on 30/11/09 at 03:03 PM Reply With Quote
I have a sectional door which has a rubber 'bumper' along the bottom and rubber strips up the side. When its closed it keeps the weather out and you can't even see the light from outside.
posted on 30/11/09 at 08:06 PM Reply With Quote
Length of pipe lagging !
MikeR
posted on 30/11/09 at 09:06 PM Reply With Quote
I did it locost style!
Stuck some gaffa tape along the whole length - 50% on the garage, 50% off. I then got some more gaffa tape and stuck that on the sticky bit and folded it over so it was on the back of the original tape (the black side).
This then drags onto the floor each time the door is closed.
