Author: Subject: OT Touch light
Chippy
posted on 5/1/10 at 11:19 PM Reply With Quote
OT Touch light
Hi, we have a couple of bed side lights that are touch operated, and one has given up the gost, the touch part doesnt work. Anyone know if this can be fixed, otherwise I will have to fit a manual switch and wire it direct. Cheers Ray
balidey
posted on 6/1/10 at 08:48 AM Reply With Quote
i had one that packed up. I took it apart but couldn't see what had broken or how to fix it, so in the end I chucked it.
Sorry, not much help.
posted on 6/1/10 at 09:40 AM Reply With Quote
We had a couple of those - the touch thing annoyed me so I rewired them with conventional in-line switches.
Bluemoon
posted on 6/1/10 at 10:30 AM Reply With Quote
In laws have loads, the electronics seem to go pop when the bulb blows.. Rubbish design!
Dan
thefreak
posted on 6/1/10 at 10:41 AM Reply With Quote
Ths missus has one of these and to me the 3 stage on switch is backwards. you touch it to turn it on (it's dimmest) then press again and it goes brighter and again to it's brightest then again to turn it off.
A real pain when you turn it on, start to doze off then want to turn the light off. It's like the bloody spanish inquisition! Is there any way to reverse the switch setup so it's brightest first down to dimmest before it turns off?
posted on 6/1/10 at 11:56 AM Reply With Quote
That's why I modified my lights - I just wanted 'on' and 'off'.
Chippy
posted on 6/1/10 at 03:04 PM Reply With Quote
Right, that doesn't make me feel that I "may" be able to fix it, so it's got to be wire up with an in line switch, shame, but there you go! Cheers Ray
Danozeman
posted on 6/1/10 at 04:06 PM Reply With Quote
Have you googled it? there must be some sort of control box in there.
Dan
posted on 6/1/10 at 04:36 PM Reply With Quote
Yep - in mine there was a small plastic box with a few screw terminals and a lead going to the lamp body (that worried me too - it's an unearthed lamp!).
It was simple to take the box out of the circuit, connect the wires up with a connection block, and fit a switch into the lead - taking care to make a decently safe job, of course. Cost me a Pound for each lamp. I think.
Bluemoon
posted on 6/1/10 at 04:47 PM Reply With Quote
Just found this link
http://www.letsfixit.co.uk/html/lamps_faq.html
Dan
Xtreme Kermit
posted on 6/1/10 at 05:19 PM Reply With Quote
nice find. That'd be it then...
Chippy
posted on 6/1/10 at 11:01 PM Reply With Quote
Bluemoon
Hi, fantastic link mate, I tried Googling but came up with zilch, must try harder, :-) Cheers Ray
