macc man
| posted on 17/1/10 at 06:09 PM |
bike carbs loose
Hi, has anyone had same problem as I have in that the bike carbs work loose on the rubber hoses. I used silicon hose but I think a better solution
must be out there. I am thinking of making short alloy sleeves to go over the carb bodies an hold with grub screws. This will give more purchase on
carbs. Any usefull suggestions welcomed.
Stuart_B
| posted on 17/1/10 at 06:18 PM |
hi, i use the orginal bike rubbers, and got my manifold ends on a lathe and cut a tappered grove out so it is a nice tight fit, and they do not
move.
  gas barrel
hth
stuart
RichardK
| posted on 17/1/10 at 06:38 PM |
This thread has a bit of info LINKY
Rich
Gallery updated 11/01/2011
whitestu
| posted on 17/1/10 at 07:01 PM |
I use bike carb rubbers and mine have never budged.
Stu
jacko
| posted on 17/1/10 at 07:42 PM |
Hi a supper glued the rubber pipe to the carbs then jubilee clips about 3years ago and still on + fitted a stay middle of carbs to the rocker cover
bolt
Jacko
[Edited on 17/1/10 by jacko]
roadrunner
| posted on 17/1/10 at 07:46 PM |
I had the same problem with mine, they just kept falling off, but not when i did this.
  zx9 carbs ties
martin1973
| posted on 17/1/10 at 07:51 PM |
i found with mine i used thinner hose clips
that stopped them slipping off the manifold.
also using rubber not silicone pipe was better.
martin
| posted on 17/1/10 at 08:51 PM |
I did the same as Stuart_B (pattern 3 - used to test the machining setup) with the original bike's rubber tubes.
[Edited on 17/1/10 by David Jenkins]
Andi
| posted on 17/1/10 at 09:34 PM |
[img]http://www.flickr.com/photos/ukone/3121848971/sizes/l/[/img]
I used some ally angle from b+q and for the struts, chopped up some threaded bar and heat shrink wrapped the threads to look a bit better.
macc man
| posted on 17/1/10 at 09:54 PM |
bike carbs loose
Hi, thanks for all the replys, I think using the original rubbers from the bike and apair of metal braces may be the best solution,many thanks.
