Author: Subject: Bike engine clutch problem
mookaloid
posted on 4/3/10 at 08:53 PM Reply With Quote
Just wondering if anyone can help with an issue I have come across with my new toy?
bike
bike
The problem is that the clutch is really sharp - to the point where it is really difficult to ride. It either stalls or shoots off like a startled cat. It seems that there is little or no room for error on the biting point and it doesn't seem able to be 'slipped' in the normal way by holding the lever at the biting point. It's more like an on/off switch which makes low speed manoeuvring very difficult.
I have ridden lots of bikes in the past and this isn't as it should be.
it doesn't slip at all and doesn't appear worn.
My good buddy (RichardK ) has suggested that it could be as simple as the wrong oil being present - could this be the cause or should I be looking at other stuff too?
Mark
owelly
posted on 4/3/10 at 08:56 PM Reply With Quote
Oil. Replace the oil with whatever the manufacturers recommend and see what happens.
http://www.ppcmag.co.uk
twybrow
posted on 4/3/10 at 09:02 PM Reply With Quote
Is the cable adjusted correctly? There should normally be some slack in the cable...
Is it cable, have you got the recommended amount of free play at the lever ?
Ditto
[Edited on 4/3/10 by Peteff]
MikeCapon
posted on 4/3/10 at 09:04 PM Reply With Quote
I doubt it's the oil. Wrong oil usually causes slippage. Cable or hydraulic clutch? If it's cable oil it. Properly. If it's hydraulic then more difficult. How many miles has it done?
ETA If the clutch does not slip then the cable free play is not a problem....
[Edited on 4/3/10 by MikeCapon]
mookaloid
posted on 4/3/10 at 09:18 PM Reply With Quote
Ok thanks chaps.
I'll change the oil anyway - does it matter if it's semi or fully synthetic?
I'll check the cable too.
any thing else? am I likely to have to take the clutch apart?
Mark
Edit: it's done about 12k miles supposedly
[Edited on 4/3/10 by mookaloid]
MikeCapon
posted on 4/3/10 at 09:51 PM Reply With Quote
If it's a cable clutch I'll put money on a dried out cable which will tend to snag as it lets out giving exactly the symptom you describe. You can buy a plastic cable oiler which you can squirt lube down to oil the cable completely. Keep oiling till you see oil at the other end of the cable.
Oh, and let us know what happens?
mookaloid
posted on 4/3/10 at 11:06 PM Reply With Quote
I certainly will
ReMan
posted on 5/3/10 at 12:05 AM Reply With Quote
Ok thanks chaps.
Mark
A BIT REVERSE LOGIC, BUT MY BLADE CLUTH DOES NOT LIKE FULLY SYNTH AND STARTS TO SLIP WITH IT, SO THAT MIGHT HELP WITH YOUR CHOICE, BUGGER CAPS ON SORRY!
