Jasper
| posted on 4/8/10 at 10:45 AM |
Caravan Question
So I've just inherited a Fleetwood Colchester caravan from my father-in-law and am gonna give it its first outing soon to the Goodwood Vintage
festival. We have a powered pitch which should make life a little easier.
Anyway, quick question, if I plug the mains in to the caravan, will it charge the onboard leisure battery, or do I have to connect a battery charger
directly too it?
I'm getting my towbar electrics adapted next week for the extra 12v output ....
mookaloid
| posted on 4/8/10 at 10:51 AM |
it should charge the leisure battery.
unless the caravan is very old, it should have a battery condition meter somewhere which will also have the charger controls net to it.
Welcome to caravanning
mark
MakeEverything
| posted on 4/8/10 at 10:52 AM |
Check to see if there is an optimiser or split charging unit on the caravan.
The question you have asked all depends on what equipment is installed.
Kindest Regards,
Richard.
Jasper
| posted on 4/8/10 at 10:58 AM |
Yes, just inside the door is a panel with the battery meter, I plugged the power in over night but the meter didn't move, it's showing
just over yellow. There's a switch next to it with van/car on it to....
Ahhh - well, I've got a mate who lives locally who's a big caravanner, think I'll take it round to his and get him to show me all
the techinical stuff with it. Unfortunately my father-in-law is not well enough at the moment to help.
wilkingj
| posted on 4/8/10 at 11:16 AM |
If you plug into the mains, you should have the OPTION to charge the on board battery.
Most caravans have an onboard 12v charger. You usually have to switch this on to charge the on board battery, its not automatic as soon as you plug
into the mains, unless you left it switched on last time!
A split charge relay (or data unit / split charger on CAN bus equipped type cars) is needed so you can charge the battery on the caravan whilst the
engine is running on the car.
You NEED the split charge relay so that when the engine is NOT running, it disconnects the caravan battery from the car. If it was to be connected all
the time, when you try to start the car, you would try to draw the starter current from BOTH batteries. No problem with the car battery, BUT the
caravan battery does NOT have the correct wire size to carry that current.
Thus you are Liable to start an electrical fire by melting the wiring associated with the caravan battery.
Also the split charger supplies 12volts to the refrigerator, and again, cuts it off whilst the car engine is not running so it does not flatten the
car battery when the caravan is connected to the car, and the car engine not running. Thus you can have the refrigerator running whislt you travel,
and have cold beer available whn you arrive, not to mention soured milk, melted butter, and smelly meat (been there with all them over the years)!
The Fridge (Most are the Electrolux RM212 - which are brilliant) draws 8 amps continuous when running on 12V, thats nearly 100watts continuous draw,
and would eventually flatten the battery in a not too long period.
I tend to put the fridge on the mains for 24 hours before travelling, and get it nice and cold with all the stuff in it that I can put in, then hook
up to the car, and then travel straight away. This way, the fridge is already down to temperature, and is less of a strain on your electrics. Also
keeps every thing nice n cold! I fridge full of room temperature food takes a good while to get it all cold, when running on 12v.
Take it from me. I've been camping for 54 years, and had a caravan for the last 19 years. (Anyone want to buy a caravan? Mines up for sale, non
smoking family use, and no pets either except the wife!)
EDIT:
PS.. The Colchester Range of vans was the top of the Fleetwood's range. Nice Vans...
Oh and remember to switch the fridge from mains to 12v before you set off, and then to switch to 240v when you get plugged in on the pitch / site.
Then the reverse on the way home. Its not automatic switching!
[Edited on 4/8/2010 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
lsdweb
| posted on 4/8/10 at 11:30 AM |
Welcome to caravanning!
I agree with everything above!
To make sure the fridge is OK, I tend to put bottles of frozen water in it and run it on mains for a few days before going away, to ensure you get it
down to temperature (12 volt running isn't good at that and is only usually good at keeping it low).
Take out the frozen bottled water and refill with cold cans of Stella. Switch to mains electric or gas when you're on site, open Stella - job
done :-)
Bluemoon
| posted on 4/8/10 at 11:34 AM |
Hate to say it but caravan is actually quite cool (we have our little eriba puck)..Have fun!
Keep the battery charged if you can they don't like going bellow about 50% discharge (about 12.4V with out any load if you have a DVM to check).
Jasper
| posted on 4/8/10 at 11:39 AM |
Cheers chaps, I'm gonna take a powered cooler box as well, as I don't think I'll be able to fit all the beer AND food in the fridge
Really looking forward to it actually now I've got one, especially as I don't have a kit car any more, it'll give me something to
tinker with and upgrade!! Mind you, I don't think we'll be going to caravan sites with it, I don't think it'd quite be my
scene, we're gonna use it for festivals as I can't be doing with camping any more.
Humbug
| posted on 4/8/10 at 11:46 AM |
Will the Mini be up to towing it?
Jasper
| posted on 4/8/10 at 11:49 AM |
Of course - those 81 horses will be plenty I'm sure
Vindi_andy
| posted on 4/8/10 at 12:16 PM |
Im just in the process of joining this caravan crowd on here.
Have bought and old rotten 'van and am in the process of stripping it out in order to build a teardrop caravan on the chassis to be towed behind
Tango
Came with 3 way fridge and hob grill sink arrangement.
When the teardrop is built will be using it for the KitCar shows as the Mrs finds camping too cold ( wimp)
followed the comments with interest as there is no 12V system in the 'van i got (it was so old the lights were gas) so I am looking to put said
system in using a Zig unit which I believe is the charger control unit all in 1 happy to be corrected and advised accordingly.
Sorry if this is hijack of original thread
Bluemoon
| posted on 4/8/10 at 12:54 PM |
Be careful of the weights. You are legaly not able to toe more than the weight of the mini. I think that's the plated weight as well.
That's why we have the puck (these are popluar with mini and VW people) as it comes in at 550Kg fully laden, so we can tow with the fiesta (or 7
if i ever get round to fitting the hitch).
Dan
[Edited on 4/8/10 by Bluemoon]
Bluemoon
| posted on 4/8/10 at 12:59 PM |
Happend on a second (older) puck last weekend on the M4 at 1am... Funny that..
[img]
  puckcaravan
[/img]
Ours is on the right a 1981 model on on the left is a lot older and will be even lighter (but more basic) than ours.
Jasper
| posted on 4/8/10 at 01:12 PM |
Dan
I think you missed the scarcasm there, I've got a BMW 530d for towing The Mini would struglle to pull the skin off a rice pudding.
jossey
| posted on 4/8/10 at 01:20 PM |
your euro cable connector from your car willl charge it on route too.
be careful with the towing using your car.
hook it up with the car loaded.
there is an issue with the Auto leveling on the e61 which i assume you have.
load the kids, wife dog and caravan. turn off the car for 30 seconds while everyone is in and then turn on and it should settle and not give the dash
error.
if you dont have the e61 ignore me lol
dave j
e60 driver. e61 repairer lol
Bluemoon
| posted on 4/8/10 at 01:31 PM |
Not unusual, need more coffee!
Jasper
| posted on 4/8/10 at 01:37 PM |
I've got the E39, so no problems, and it's just had two new air bags at the back...
Vindi_andy
| posted on 4/8/10 at 02:33 PM |
I believe the legal limit is 80% of the towing vehicle for a braked chassis
Plus there will be a maximum train weight for your car listed somewhere either on the vehicle plate or in the handbook
steve m
| posted on 4/8/10 at 02:43 PM |
Japer,
welcome to the dark side !!
we also have a cvan, just a 2 berth, for the missus and me, lus grand kids !!
i was initialy against the idea, but now quite enjoy the whole caravan experiance, all except rain on yor last day before packing up, a real PITA
Jasper
| posted on 4/8/10 at 04:12 PM |
Yeah - never though it would happen - but it was free!!!
And like you, it's only for the wife and me and maybe the dogs too.
Not sure where else I'd use it but car shows and festivals though, I really don't fancy a caravan site with a bunch of beardy wierdes
talking about their velour soft furnishings and what the best loo chemicals are ...
zilspeed
| posted on 4/8/10 at 04:55 PM |
I have 'a friend' who quite fancies a folding caravan to tow behind the Citroen Synergie he has.
(Just like me, how odd is that ?)
'His' Synergie can be used for sleeping, but it wouldn't be much fun having nowhere to keep 'his' family's kit
in.
Ahem...
Anyway, are they cack, or is it not a bad idea ?
What should 'my friend' look out for ?
It's not me obviously, oh no.
SteveWalker
| posted on 4/8/10 at 07:14 PM |
Nearly right. The caravan club *recommend* 85% maximum.
The legal limit for an unbraked trailer is the lower of 750kg or half the car's kerbside weight.
For braked trailers it is the maximum set by the manufacturer (and specified either as maximum gross weight of the trailer or the permissible gross
train weight of the car and trailer). I have owned a car that had a kerbside weight of just over 1500kg and a max allowed towable weight of 1800kg.
The law specifies a maximum trailer weight of 3500kg (where the towing vehicle and driver's licence allow) for overrun brakes.
I'm not sure if this still applies, but with the right sort of brakes (hydraulically or pneumatically linked) some landrovers are apparently
plated to tow 4 tons!
SteveW
ken555
| posted on 10/8/10 at 10:56 PM |
SteveW
So in our case, we can tow anything we want ?
Nothing on my "Chassis/Vin" plate about weights, just the numbers I stamped there.
