Author: Subject: ot wood burner flue fitter
JAMSTER
posted on 28/8/10 at 07:59 PM Reply With Quote
i need someone to fit a stainless steel flue for a new wood burner i've bought but they are to be hetas registered help please or recomendation
peterborough area
thanks
T66
posted on 28/8/10 at 09:00 PM Reply With Quote
do it yourself and dont tell anyone....
Fireboard and fire cement required.
posted on 28/8/10 at 10:01 PM Reply With Quote
If you're doing it yourself you don't need to be registered only if you're charging for it.
I fitted my own fireplace today.....
Andi
posted on 29/8/10 at 09:44 AM Reply With Quote
Yep me too.
DIY
posted on 29/8/10 at 10:39 AM Reply With Quote
I've had a flue fitted recently - there are 2 official routes. The first is to use a HETAS installer, who takes responsibilty for meeting building regs.
The alternative is to use an ordinary builder (or do it yourself) but you'll have to get a building inspector in to check the installation of the hearth, flue and the surrounding materials around the stove.
I went the HETAS route for simplicity's sake.
Wheels244
posted on 29/8/10 at 04:00 PM Reply With Quote
What size burner is it ?
Only have to involve Hetas\Building Control if it's over 5Kw.
I've got two fitted in my house.
I did the 1st one by myself as it was only 5KW.
Got a Hetas engineer to fit the 11KW with built in boiler and got a thermal store installed athe same time.
