McLannahan
| posted on 18/1/11 at 09:19 PM |
Plastering/Tiling question
Evening - I'm trying to re-do my kitchen and have started in earnest tonight!
I'm removing the tiles and most of them have come off easily and cleanly.
They have though pulled off the 2mm skim of plaster revealing the rough plaster/cement underneath. It's uniform and looks fine - there's
no big holes or anything and the base seems very sound. It's a normal wall - not stud or plasterboard and the house is quite modern (1996)
Can I put the new tiles back on to this base or do I need to have the wall re-skimmed?
Thanks everyone!
Michael
designer
| posted on 18/1/11 at 09:24 PM |
I would give it a coat of PVA to seal and tile.
tegwin
| posted on 18/1/11 at 09:26 PM |
If its a cavity wall with a proper damp proof course I would just go right ahead and tile over the render....might need a little extra adhessive, but
it will be fine
www.verticalhorizonsmedia.tv
bigrich
| posted on 18/1/11 at 09:27 PM |
I know i would just get on and tile over the missing skim coat. not sure if its technically the right thing to do but i would and have done in the
past.
I think the adhesive would key better to the rougher plaster instead of the smooth top finish?
McLannahan
| posted on 18/1/11 at 09:36 PM |
Fantastic - Thanks everyone. Have got some PVA too somewhere so I'll slap that on and carry on! I'd feel bad if it was a huge chunk
missing but my thoughts were as everyone else's!
Thanks chaps!
Michael
| posted on 18/1/11 at 09:41 PM |
Slap the tiles straight on.
LAst tiling I did I didn't even bother with proper tile adhesive and just stock them on with no more nails and grouted them in as normal - rock
solid and much quicker and cleaner than messing about spreading adhesive on the wall.
McLannahan
| posted on 18/1/11 at 09:53 PM |
I like the sound of that! That's my kind of half-arsed solution Nick!
| posted on 18/1/11 at 09:54 PM |
If its as new as you suggest then you should be fine straight onto the existing - just make sure you get them all even! Old types of plaster can be
very dusty or crumbly and i dont think the adhesive would stick.
McLannahan
| posted on 18/1/11 at 10:03 PM |
It's not dusty or crumbly at all Joel - seems like a really solid foundation. Having seen the neighbours kitchen I know ours is original too as
the units are the same. So by my reasoning the plaster is original and as old as the house, 1996.
I've not done much tiling before - only patching up the bathroom so this will be interesting! Fingers crossed I'll get them even!
lsdweb
| posted on 18/1/11 at 11:58 PM |
Lots of good tips here - http://www.ultimatehandyman.co.uk/
| posted on 20/1/11 at 02:27 PM |
Well there's no point overdoing it on the effort front is there
