McLannahan
| posted on 18/1/11 at 10:38 PM |
Make my own glass splashback?
Sorry - another refit kitchen question!
Glass splashbacks seem to be crazy money and I was wondering how feasible it might be to make my own?
Have glass cut to size and then paint the back of the glass? Would only want a plain colour and I'd like to cover a panel that's about
2000mm by 500mm but could be done in multiple pieces?
Am I going clinically insane or does this sound like a plan?
austin man
| posted on 18/1/11 at 11:00 PM |
shouldnt see why not, it would have to be toughend or laminates with ground edged unless you are using an edging strip. You would also need a lot of
prep to get the painting to look good you may be better having vinyl applied as it would look more consistent.
StevieB
| posted on 18/1/11 at 11:01 PM |
quote: Originally posted by McLannahan
Am I going clinically insane...?
Yes!
By the time you get the glass cut (including all the holes for sockets/switches etc) and get the paint right, you won;t be far off the cost of an off
the shelf splash back.
The idea occurred to me some time ago and I did all the costing up and decided that it really wouldn't be worth all the effort and 80% of the
cost to achieve something that's only 50% of the end result.
indykid
| posted on 18/1/11 at 11:02 PM |
sounds fair.
get it frosted for a key, then spray it?
mcerd1
| posted on 18/1/11 at 11:12 PM |
you've got me thinking about my kitchen now.....
frosted on the back sounds like a plan - what paint would you use though?
also what about waterjet cutting for the fancy bits (sockets etc....) all you'd need it some good measuring (card template then measure that
maybe)
then draw it up in CAD - plenty folk here could do that bit for you if need be (inc. me)
not sure how you'd round off the exposed edges, but I guess it wouldn't matter much for the sockets and waterjet gives a fairly decent
finish anyway
[Edited on 18/1/2011 by mcerd1]
woolly
| posted on 18/1/11 at 11:20 PM |
before you make your mind up have a word with these guys,
they are over the road from me.
COLOURED GLASS UPSTANDS SPLASHBACK SPLASHBACKS on eBay (end time 06-Feb-11 13:23:58 GMT)
McLannahan
| posted on 18/1/11 at 11:26 PM |
I did think of that but thought that just one hair or a bubble and it's all over! Not looked into it enough yet but would hope to buy the glass
cut and prepared to avoid needing a edge strip? Thanks AM
McLannahan
| posted on 18/1/11 at 11:30 PM |
Yes!
Trouble is that for the size (and sizes if successful?) I'd need it really does add up! Admitedly I'm not taking the switches hassle into
account and I know that'll not be easy! Luckily there's only two standard double outlets on this wall so not too complex but as
you've said - I'm probably over-simplifying it!
McLannahan
| posted on 18/1/11 at 11:52 PM |
Do look quite reasonable - Thanks for that Wooly. Have just emailed them to see if any of this plan might be within my sad budget!
skodaman
| posted on 18/1/11 at 11:57 PM |
You can get drill bits for glass
up to around 7mm in diy places which is okay for screws. I don't know what sort of paint would be best but I've used blackboard paint,
normal gloss and normal emulsion on the backs of fish tanks and it doesn't stay as a perfect finish for long, yet it's a pig to get off
and redo.
Skodaman
HowardB
| posted on 19/1/11 at 06:42 AM |
I know it's a bit retro, but I did mine in satin stainless steel. looked ok and for £200 was much cheaper than the shop stuff. Local fab shop
cut it for me.
hope that helps
designer
| posted on 19/1/11 at 08:59 AM |
I got my glass one at IKEA.
karlak
| posted on 19/1/11 at 10:00 AM |
We have just been through this....
Got our new kitchen being fitted in February and went from a Stainless brush steel splash back (which actually shows load of marks and is a pain to
clean) ,, to considering Glass. But in the end for us, we went for a matching Granite one, it will match the worktops and was not that much more than
a Glass Splash back of the same size.
I did really like some of the "cracked glass" designs out there though. A mind boggling choice of styles and finsihes.
[Edited on 19/1/11 by karlak]
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
