dhutch
| posted on 13/6/11 at 11:37 PM |
Defective vehical dispute.
On Saturday I was given a HORT1 for a missing rear bumper.
I have no issue with producing my paperwork to my nominated station, however as the car is in the exact same condition as it was presented for its MOT
6 months previously which, with minor alterations to provide a numberplate light and to reduced sharp edges, it passed. With the only advisory item
being the missing bumper i feel obliged to question the discrepancy. It not ideal, but its not bad, and it passed without issue. The car is otherwise,
in a tidy and original state.
Following advice given by my local station i have requested to speak to the PC's Sergent, however he is away for the week.
It has also been suggested on another forum I have the car re-MOT'ed or take it for a 'Modified Car Test' whatever that is.
Not quite sure how I would request a second MOT without arousing suspicion but otherwise this appears to be a good idea.
Any advice welcomed in this hour of need!
Daniel
snapper
| posted on 14/6/11 at 05:50 AM |
I take it this is for a tin top modified to remove rear bumper?
If so you are in a bit of a grey area.
If you are going to dispute this with plod make sure all your other documentation is 100%, I.e. Your insurance company are fully aware of the
modifications, this is what plod will scrutinise next.
I eat to survive
I drink to forget
froggy
| posted on 14/6/11 at 05:55 AM |
Mot legislation is the the road traffic act , the police use construction and use regs . Put a picture up of the car with no bumper .
If you have a sharp edge or other defect that would be in breach of c+u then he can stop you and deal with you accordingly . As you haven't been
given a vdr ( defect rectification notice) im not sure what your problem is ?
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
dhutch
| posted on 14/6/11 at 06:40 AM |
Yes this is correct, a Peugeot 306 with rear towbar fitted.
quote: Originally posted by snapperIf so you are in a bit of a grey area.
Although I can make changes to both the car and insurance policy, at the time of the
alleged no 'modification' was recored on the insurance. I informed them i had a towbar fitted which they say they did did not need to
recored and that the rear bumper was missed and had been since the mot, which they also said was fine as long as it was ok by the MOT. But again this
was a verbal and i have no record of it.
jabs
| posted on 14/6/11 at 06:41 AM |
Why would a HORT/1 be given for a missing bumper? He may have stopped you because the bumper was missing but I then assume you got the HORT / 1
because you couldn't show all your documentation to him.
dhutch
| posted on 14/6/11 at 06:48 AM |
Annoyingly i have also lost my camera the same weekend, and my phone is in for repair (talk about buses) but I will try and find a camera i can borrow
and get a photo of it, both for the forum and my own record.
The sharp steel edges have been covered (with body colour silver tape) to a radius of around 4-5mm, the two pertruding bump mounting brackets toa
simular radius using bicycle innertube, leaving just the relatively flexible plastic arch liners, which have an edge around 3mm thick, which appears
to be one of his areas of contention. There is also around 10mm intrusion on the otherwise standard numberplate which he highlighted.
I have not been given a rectification notice (although he advised i was required to correct the fault before driving the car again) however I
understand he has, or is going to, fill a report against me which will emerge as a court summons. I already have 11 points for a flurry of speeding
offenses two years ago. (otherwise clean for 6 years)
Thanks for you help so far.
Daniel
dhutch
I had my photocard with me, which he saw, but not my counterpart of MOT/Insurance which are the other docs he has requested.
r1_pete
| posted on 14/6/11 at 07:19 AM |
HO.RT/1 is issued for non endorsable offences, just produce your documents within the 7 days, and take it from there.
Can't you refit the bumper with a cut out for the towball? if you show some effort to rectifying the issue they have, no doubt they will let
things go, no point going into battle with them for what could be an easy fix, and one which will make your car look a whole lot better.
dhutch
| posted on 14/6/11 at 07:48 AM |
quote: Originally posted by r1_peteCan't you refit the bumper with a cut out for the towball? if you show some effort to rectifying the
issue they have, no doubt they will let things go, no point going into battle with them for what could be an easy fix, and one which will make your
The problem appears to be that when peogote face lifted the 306 (mines a v-reg) they bear in mind the towbar meaning the main bar fouls right the way
along the center by about two inchs which would need a 3ft wide area removing. I thought i was going to make my life easy by getting the OEM bar (used
of ebay) but it turns out i would proberbly have been better with a witter bar although i havent seen one of these fitted to a facelift model.
Obvisouly with hinds sight i would have dont things diffrently but having thought the advice of the local garage and be told it would not be an issue
(for the MOT or otherwise) I didnt think much of it. I live opersite the police station in Uttoxeter and am often followed down the road by a polcie
car and have never had a car stop me for the bumper.
IM certainly going to get it sorted, and in the mean time remove the towbar and refitt the bumper before i drive the car again. However before I do
that i would like to have it inspected in its current state and photograph it.
Hence the plan to get it re-MOTed, by the same garage or another. What do you think of the suggestion of having the car put through a ESVA to get a
more indepth test?
Daniel
Ninehigh
| posted on 14/6/11 at 08:04 AM |
Ok this brings up a few questions, which may or may not be relevant.
1. If it's defective how does it get past an MOT?
2. If you live NEXT DOOR to a police station, and been followed half as many times as you claim how's it taken them six months (at least) to
figure this out.
3. How is it defective? I mean how do you know fitting some chunks of bumper is going to do any good
4. Have you been ordered to rectify the "problem"? By the sound of it this is just a producer of documents
r1_pete
| posted on 14/6/11 at 09:00 AM |
Personally I just wouldn't go into battle over this.
You are going to re fit the bumper, produce your documents, whuch should be an end to the rozzers interest.
Now please dont take this as patronising, but, if you can build a car, you can overcome the issue of the towbar fouling the bumper, as you live close
by the police station, it really isn't worth being marked, do as they ask and they'll leave you alone.
steve m
| posted on 14/6/11 at 09:04 AM |
Take the tow bar off when not towing and fit the the bumper
dhutch
| posted on 14/6/11 at 10:29 AM |
figure this out.
1. It has been suggest by the officer that certain items may pass an MOT but not police requirement, however other sources suggest that although this
is the case, the rear bumper is not one of these areas.
2. I havent been pulled by my local force, the alogation comes from an officer in the DyfedPowys region following my driving to Aberythwith to collect
my girlfriend and help her move as she just graduated.
3. In partiuarlar i understand he took issue with the sharp edges of the plastic arch liner and the fact that the top 10mm of the number plate was
obsured by tape. And just generally stated that it being missing was an offence.
4. I have had no written order to rectify the problem, the only paperwork i took away was the HORT1, however he is verbally advised it must be
corrected before the vehical is driven again and as said, I understand he is putting together a file which will result in a court summons.
I largly agree with this, but as I am already on max points I dont want to leave anything that might result in a ban to chance. I dont want a fight, I
jsut dont want penaising for something im dont belive im guilty of.
I also take you point that i could have found a better solution beforehand, and with hinds sight I agree, however at far as im aware it is not and was
not illegal so didnt consider it overly important.
Daniel
blakep82
| posted on 14/6/11 at 10:43 AM |
lol, loads of people saying refit the bumber and forget it.
remember that of all the cars built by people on here, how many have bumpers? so this copper is saying everyones cars on here are not legal because
they don't have a front or rear bumper?
speak to the sargeant, the copper that pulled you clearly doesn't understand the law, this is a minor thing, could be something more serious,
with bigger consequences that he gets wrong next time. a bit extreme maybe, but his errors need pointing out imo
edit: reading earlier posts, with the hort1 (producer), asking for license, mot, insurance etc, seems like the normal info asked for any similar sort
of stop. if thats all they want, then theres no issue really
[Edited on 14/6/11 by blakep82]
________________________
dhutch
| posted on 14/6/11 at 11:40 AM |
I think speaking to his sergeant has to be a good call, unfortunatly he is off this week, but I shall be endevoring to speak to him on his return for
sure. As is finding a solution where the bumper can be fitted with the towbar.
I however also keen to get some sort of profesisonal 3rd party assement done before any changes are made.
If it was just a producer all would be ok, but as I say, he read my a caution and I understand he is taking it to court, which is the issue, partiarly
as any points at all would result in a totting up ban.
Daniel
stevebubs
| posted on 14/6/11 at 02:54 PM |
Was it in or around aberystwyth? If so, there is a known local copper who likes to pull on the slightest things....he's even been known to take
a light meter to measure the light passing through factory fit windows...
stevebubs
| posted on 14/6/11 at 02:55 PM |
Take it to your local police station (it's opposite) and ask their opinion...don't say why, just that you have a problem with the tow bar
and want to make sure you're still legal...I'm sure someone will walk over the road with you...
blakep82
| posted on 14/6/11 at 03:03 PM |
hmm, didn't think a copper was allowed to do that, thought only someone from vosa could test that? in which case, how is his particular meter
calibrated and approved? hmmm
mrwibble
| posted on 14/6/11 at 03:29 PM |
sounds to me like its approved by captain jobsworth powertrip.
dhutch
| posted on 14/6/11 at 03:44 PM |
Interestingly enough, not only was it while driving through aberystwyth but he did mention the measuring of window tints at the time.
Daniel
[Edited on 14/6/2011 by dhutch]
dhutch
The Police station is only open 9 till 5 and as I work 8.30 till 5 (Mon till Fri) I can only usally get there on Fridays when I finish at four. But Im
hoping to take an hour off tomorrow afternoon in order to do this.
I have also phoned the garage who passed the car (also on the same road) who also sounded supprised that it had become an issue. And am taking it in
tomorrow for them to inspect. They say that assuming its in an MOTable condition (which i assuming it is, as its not changed in the 6months since it
last past) that they would be more than happy to sign off a defect form. So watch this space i guess.
Daniel
robinj66
| posted on 14/6/11 at 05:40 PM |
Daniel
The HORT/1 ("producer" is just a requirement to produce the documents named in that form at a specified police station within 7 days.
This used to be fairly routine after a "chat with the boys in blue". Remember to take both parts of your D/L. You should be given a HORT/2
when the docs have been produced.
NB it is a separate offence to fail to produce any of the documents specified in the producer. You would get penalty points.
The reading of a caution etc is a verbal Notice of Intended Prosecution (NIP) - that puts you on notice that any possible offences are under
investigation and that you may receive a summons to court at some time in the future.
Do get photos etc of your car in it's current state and someting in writing from your MOT tester etc to confirm your vehicle is not in a
dangerous condition.
If the worst comes to the worst, seek legal advice (especially if you asked to the police station for a "chat" but not all Dangerous use
offences are endorseable (carry penalty points)
dhutch
| posted on 15/6/11 at 09:27 AM |
quote: The HORT/1 ("producer" is just a requirement to produce the documents named in that form at a specified police station within 7
days. This used to be fairly routine after a "chat with the boys in blue". Remember to take both parts of your D/L. You should be given
a HORT/2 when the docs have been produced.
Taken an hour off
work today to do this, will make sure I get a HORT2.
quote: The reading of a caution etc is a verbal Notice of Intended Prosecution (NIP) - that puts you on notice that any possible offences are under
Took photos last night, went home to parents to collect docs and use there camera, sadly dad had taken it with him visiting my sister and ended up
using a phone but the photos look ok and i got some close ups to make up for the reduced quality.
Car is currently at the Garage that origanally MOTed in 6months ago and i have reqested they do another full MOT and write a letter stating in there
eyes the rear is ok, and that the general presentation of the car is good.
IM also going to a Soliceters today to sign the documents for my house so will enquire as to what they can offer by way of legal advice on the
subject. I have legal cover with my motoring insurence, although im not sure what it covers.
Daniel
dhutch
| posted on 15/6/11 at 12:21 PM |
Well, for whatever its worth, it passed an MOT today without complication.
loggyboy
| posted on 15/6/11 at 07:04 PM |
Sure the answer is to fit one that does allow the bumper to be retained.
