morcus
| posted on 8/7/11 at 02:55 AM |
Can I make Gin at home?
Weird question I know, but to settle an arguement does anyone know either way If someone can legally distill gin in there own home or would you need
some sort of lisense?
Also, if you can make Gin at home, anyone know how to do it?
LBMEFM
| posted on 8/7/11 at 04:04 AM |
Try Googling "How do I make home made Gin", there are some fasinating receipes there with or without using a still, especially from the
USA. As for legality who is going to know as long as you don't try to sell it. Barry
LBMEFM
LBMEFM
LBMEFM
| posted on 8/7/11 at 04:07 AM |
Don't know what happened there with regards to three replies. Maybe it is too much home made Gin or what the hell are we doing up at this time
of night.
Ninehigh
| posted on 8/7/11 at 04:44 AM |
Legal? Don't know, it's legal to make beer and whiskey so why not something minging that's only drunk by old women?
cliftyhanger
| posted on 8/7/11 at 06:14 AM |
I think the distilling process needs to be done with great care to avoid concentrating poisons, potentially lethal (I jest not)
I think a safer method is using the freezer. Water freezes first, take bits of ice out of your brew, and the % will go up.
However, I believe there are yeasts out there that can be used to brew (just like wine) "spirits" but up to a max strength of 20 odd %.
stevegough
| posted on 8/7/11 at 06:32 AM |
Like anything you made at home...you would have to IVA it.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
| posted on 8/7/11 at 06:56 AM |
If the still temperature is just a few degrees wrong you get methanol (the nasty stuff) instead of ethanol (the good stuff). Ethanol makes you drunk,
methanol makes you blind, and screws up various internal organs - basically, it's meths without the purple colour and evil taste.
Risky, if you don't know what you're doing!
hughpinder
| posted on 8/7/11 at 07:38 AM |
try www.homedistiller.org
The good old UK government forced the gin makers to register what they put in in the 1880s(I think), so on that site you can find the difference
between beefeaters/gordons/bombay saffire etc.
As long as you register for 'home use' (I'm not sure how) you can make 'small' quantities for your own use (but not for
sale/distribution). The definition of small is something like 5000l/year so I doubt you'd exceed that. If you don't register its
illegal.
When you distill, the methanol boils off first, so its normal to put the first 100cc or so aside for use as cleaning solvent or meths - When it first
starts to distill through its quite tempting to have a sip to see whats its like - thats why backwoods distillers went blind - the first bit is pure
methanol.
One of the reasons freezing is not generally used to make drinking alcohol is that any impurities get left in (you freeze out the water, but
dissolved nasties/bad tastes stay in there), whereas distilling tends to leave most of the bad stuff behind in the still.
When you distil, some does not recondense and you can smell the alcohol from about 100meters away.
All my knowlege is purely theoretical of course......
Regards
Hugh
[Edited on 8/7/11 by hughpinder]
MikeFellows
| posted on 8/7/11 at 08:18 AM |
my understanding was that its illegal to distill at home, i looked in to it a few years ago as I fancied making vodka
Vindi_andy
| posted on 8/7/11 at 08:43 AM |
As I understood it, it is illegal to distill at home.
In addition to the reason the backwoods guys went blind there was also a spate of people using second hand radiators to condense the distillate which
picked up all the nasty stuff from inside the radiator
There are some self brew kits available that will by fermentation produce a reasonable tasting gin at around 20%. Just means you have to use a double
measure
And you dont need to make a still all you need is a demijohn and a food grade plastic bucket
Dont ask me how I know
JeffHs
| posted on 8/7/11 at 09:28 AM |
http://www.wineworks.co.uk/department/still-spirits/?gclid=CObA8OC28akCFcce4Qodvg8mVg
just one of many. My local home brew shop sells all of the stuff needed to make something alcoholic that you coold describe as gin or brandy or
whisky, but I stick to single malt - there's no way you can make that in an afternoon!
mad4x4
| posted on 8/7/11 at 11:12 AM |
Have a look at
Alaskan
-Bootleggers-Bible
I bought it and it tell you how to make all sorts as well as making equipment like capers and stills
Scot's do it better in Kilts.
morcus
| posted on 8/7/11 at 07:19 PM |
So to summerise, To make real, safe Gin I need permission from the government (I'm reading it that way because my original argument at work was
just that) but I can make something simillar to gin at half strength with wine making type stuff and I won't kill myself or go blind as a direct
result.
