cloudy
| posted on 13/8/11 at 02:30 PM |
Garage floor tiles for about £10 per sq m ?
Does anyone know where I can get some (new or used) interlocking garage floor tiles for around £10 a square meter (need 36 sq meters) I can just
about do it with rubber rolls, but i'd rather interlocking stuff so it doesn't move at the joints...
Anyone have any good sources? Ebay seems to start at about £20 per sq meter...
James
www.warnercars.com
richardR1
| posted on 13/8/11 at 02:42 PM |
Best i have found for quality tiles are these on the bay PVC Factory Flooring rubber heavy Floor tiles £17.99psm | eBay
MK Owners Club Member 1015
mark chandler
| posted on 13/8/11 at 03:28 PM |
I saw some big rubber 4'x8' sheets of interlocking sheets at an agricultural supplier last year, maybe worth having a look, used for sheep
pens and the like.
They had solid and with holes, this was at Scats in Heathfield BTW
Regards Mark
Tatey
| posted on 13/8/11 at 04:36 PM |
I bought 21m² of rubber interlocking hidden joint flooring tiles from this company (I went for the raised disk style):
www.eco-tile.net
The online price states £25 + VAT/m² however I managed to get all of my flooring for £200. If you ring up the company they have some grade B stock
which is available, my flooring was perfect, they were just trying out a slightly different shade of grey and could therefore not sell it as perfect
stock.
I did a bit of haggling on the phone with the woman which got the price so low, I also picked up the tiles from their factory/warehouse.
I've used the flooring for nearly a year now and its been perfect, so much nicer to work on, keeps the concrete dust at bay. The only issue
I've found that welding spatter leaves marks in the floor as it melts it slightly but I have a fire blanket which I put down that seems to stem
the issue.
The flooring has been very hard wearing and has recently been moved from one garage to another, and came up and went down really easily with no
issues.
cloudy
| posted on 14/8/11 at 12:04 PM |
Thanks, I'll ring around and see what I can do...
James
www.warnercars.com
geoff shep
| posted on 15/8/11 at 07:41 PM |
These work out at about £15 per sq m
http://www.dura-tex.co.uk/-stable-mats/43-interlocking-eva-stable-mat-18mm.html
