Author: Subject: OT Building Regs
serieslandy
posted on 20/8/11 at 03:16 PM Reply With Quote
OT Building Regs
I'm about to convert my loft and have been told that around the chimney I cannot have the studs touching it. I've been looking though this page of building regs and cannot find what I'm looking for.
I need to know how far away from the chimney I have to have the studs or can they go directly up against the chimney.
The chimney is a mixture of block and eng brick near the top.
I hope I get the right answer from you lot.
Cheers Steve
keith777
posted on 20/8/11 at 03:57 PM Reply With Quote
cant see why you cant use metal studding and fireline boards
cheers Keith
JohnH
posted on 20/8/11 at 06:14 PM Reply With Quote
Have you spoken to your building inspertor ? He will be able to give you the answer you need.You should be able to use timber around the chimmney stack,as long as there is no leeks in the stack....You could always dot & dab the stack. I am a joiner by trade.Alway ask the building inspector,he shouldnt charge you. Good luck mate.
John
