McLannahan
| posted on 15/10/11 at 10:02 PM |
Heating my conservatory
It's really cold in there during the winter months and with it rapidly approaching I wonder if the collective have any ideas?
There's no carpet in there - terracotta tiles. Can't afford to install at present
There's no radiator in there either. Too expensive to install and we have microbore system
Would a heat convector type heater be too costly to run?
Thanks all
clairetoo
| posted on 15/10/11 at 10:08 PM |
How about a gas bottle-based log burner ? Make it from scrap , scrounge some wood , and its free heat !
Thats what I'm doing for my workshop...............
Its cuz I is blond , innit
Claire xx
Will weld for food......
balidey
| posted on 15/10/11 at 10:09 PM |
we have a small electric convector in ours. Quite a large conservatory, very small heater, but its enough to knock the chill off. Yes it takes an hour
to feel it, but it does work. its small, about 8 inches high so sits on our very low wall with no bother.
If I were you I'd get one from Argos, try it and if it works great, if it doesn't, well its only £30.
We have this one...
argos
[Edited on 15/10/11 by balidey]
Dutch bears have terrible skin due to their clogged paws
NigeEss
| posted on 15/10/11 at 10:17 PM |
I'd go log burner option if I had a conservatory.
Which I haven't as theyre too cold in winter, too hot in summer.
So IMHO they're a bit pointless
balidey
One thing I was meant to do this summer was line our roof with the reflective foil tapes. It reduces heat in the summer, but its also meant to (very
slightly) insulate and retain heat in the winter.
watsonpj
| posted on 15/10/11 at 10:19 PM |
we had a conservatory at the last house and heated it with an oil filled rad. Heats up fairly quickly and did more than just keep the chill off and
there pretty cheap for 1.5kw
linky
Pete
geoff shep
| posted on 16/10/11 at 01:30 PM |
I've got things like this, wall mounted. Only addition would be a timer to get them on before we get up - there are some with timers built
in.
B&Q Heater
McLannahan
| posted on 16/10/11 at 02:17 PM |
Thanks all - will get going sorting something for the coming weeks!
cliftyhanger
| posted on 16/10/11 at 02:53 PM |
Importantly, when and for what do you use the conservatory?
Little cheap 2kw fan heaters are quick to heat an area, but no electric stuff is cheap to run for long periods of time.
Ours houses the washing machine, tumble drier and the bikes. And in winter the gas barbeque. I may, one day, try to improve it. Just may.
| posted on 16/10/11 at 08:30 PM |
insulating the floor will help a little, unless you always have slippers on! Id aim for a nice carpet and underlay, with a small oil filled rad to
warm the air.
In fact if it were mine and i were a single man, id just kingspan two of the walls Sadly the wife doesnt like that idea...
