COREdevelopments
| posted on 17/10/11 at 07:18 PM |
Garage roof help.
Evening all.
I am looking for some advice from any roofers or or anyone in the building trade. I am currently building a timber garage and am in the process of
looking for a roof. I will be using tile effect box section but am worried about condensation so was thinking of using breathable membrane under the
box section, Is this a sure way to cut out condensation? I am aware you can get anti-condensation sheets but I have worked out that it will be cheaper
to use breathable membrane if it will work ok.
any help would be very much appreciated.
Regards
Rob
stevegough
| posted on 17/10/11 at 08:18 PM |
I have a very large garage, and it was roofed with corrugated metal sheets, (it was like that when we bought the house). As you say, the condensation
was horrendous. - I lashed out £1200 to get it spraybonded (it was 45 sq metres!) The spraybond worked a treat - more pics in my archive under
'garage condensation problem'.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
mcerd1
| posted on 17/10/11 at 09:10 PM |
quote: Originally posted by stevegoughI lashed out £1200 to get it spraybonded (it was 45 sq metres!)
ouch
I'm looking into this just now for my new garage (tin sheet), but I think you've just scared me off getting it spraybonded - I've
got nearly 80 sq.m
I think I'm going to end up framing it up for a ply lining with the cheapest insulation I can get, but I'm still working on the
details......
DixieTheKid
| posted on 17/10/11 at 10:16 PM |
Breather felt will work you a min air gap of 25mm either side for it to work properly. We do one called vent 3 its £69 a roll + vat for 75m2 (1.5 x
50mtr)
COS IT'S Worth IT
COREdevelopments
| posted on 18/10/11 at 06:31 PM |
Thanks for the replies guys. I will go for the breather membrane and insulate it if need be at a later date.
Cheers guys.
Rob
