beaver34
| posted on 20/10/11 at 08:49 PM |
Space heater
Hi all,
After some opinions, need to heat garage so I can work on car, only small single garage,
What do people use? Looked at electric fan units on bay around £55 or the Clarke little devil gas units at £90
Pro and cons I suppose or any personal experience?
dave r
| posted on 20/10/11 at 09:02 PM |
gas heaters condensate and make everything rust
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
ChrisW
| posted on 20/10/11 at 09:05 PM |
..but they're a lot cheaper to run, as long as you've got decent ventilation to get rid of the condensation.
Chris
My gaff my rules
SteveWalker
| posted on 20/10/11 at 09:25 PM |
You could look for a second-hand gas caravan heater, I think some of those are room sealed and have an external flue to go through the wall.
In fact, if you can find somewhere to sell you the jets, you can make any mains gas appliance run on lpg.
adam1985
| posted on 20/10/11 at 09:39 PM |
No you cant
designer
| posted on 20/10/11 at 10:13 PM |
For a small single garage get one of those rotating Halogen heaters and move it with you.
rallyingden
| posted on 21/10/11 at 06:11 AM |
Do it the locost way........................... Put anaother jumper on
RD
kipper
| posted on 21/10/11 at 07:22 AM |
I would urge caution on using lpg gas heaters in confined areas such as small garages.People have died in caravans from carbon monoxide poisening.
I may be wrong but please check.
Regards Denis.
Where did that go?
Daddylonglegs
| posted on 21/10/11 at 07:41 AM |
I use a Halogen one, works fine for me
Slater
| posted on 21/10/11 at 08:24 AM |
Thermal Coveralls and hat, plus do a few star jumps to get the blood flowing.
James
| posted on 21/10/11 at 08:34 AM |
RD
Agreed! Wear pyjamas under you jeans and a bunch of layers on your top half...
... and man the f'ck up!
James
- Muhammad Ali
| posted on 21/10/11 at 08:35 AM |
I used to put my propane blow heater on for 10 minutes before I went in the shed then switch it off when I went in as it was too hot to work with it
on. Warm the air with the propane then use a little halogen to keep your back warm.
James
| posted on 21/10/11 at 10:50 AM |
There's a way that's free and makes you car faster through lightening too...
Press-ups!
You wouldn't believe how warm you get doing 60 of them!
James
- Muhammad Ali
