afj
posted on 27/12/11 at 01:01 PM |
electric box what is it?
This is placed outside our house, there is one every 6/8 houses, our house no. is 40 but it says 60 on it and says electricty on it
its in the way of our planned extension has anybody got an idea of what it is
ETA its 2ft high and the black wires are nothing to do with it they are for the sky tv and the fibreglass grey box part is sat on top of the base
which is concrete
[Edited on 27/12/11 by afj]
eerrrrrrrrrrrrrrrr
snapper
posted on 27/12/11 at 01:36 PM |
This is a bit of conjecture but if your estate is a good way from a mains distribution site to combat voltage and amperage drop they may run 3 phase
and use a box like you have to split down to single phase for a group of houses.
Just an educated guess.
You will need to talk to national grid to see about moving it, looks like it needs to be outside the property
I eat to survive
I drink to forget
wilkingj
posted on 27/12/11 at 04:34 PM |
It's probably be a distribution box feeding several houses.
ie large cable into the box, and several smaller cables out to the houses.
Anyway, three phase will not combat any line losses / volt drop etc.
They would only feed one phase into a house, unless you had some good mates on the local electricity board to sort it out for you
There may well be three phase in the box, but they would only be spreading several houses across the phases to manage the load.
ie each house will only have a single phase supply to it.
I would get in touch with the local electricity company, power gen or whomever.
The local planning people might know, especially if anyone else has had an extension built over one of them.
hek with anyone lese in the street who has an extension etc.
Could be costly to move it!
Make sure you get your P. Permission before paying the Leccy Co to move it!
cos they will move it, and you might not get your planning permission, hence money wasted.
Get a quote in writing first. It might be cheaper to move home!
EDIT:
If your estate was too far from a supply to cause it to have a volt drop, they would supply the area with a higher voltage line eg 11Kv and then
transform back down to get the 240V for the domestic supplies.
Our Building had its own 11Kv feed and substation.
We also had 3 x 2.5Mw diesel Generators.
[Edited on 27/12/2011 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
