prelude1980
| posted on 1/1/12 at 12:32 PM |
Central Heating Programmer
Hi all,
Hope your having a good New Years Day.
I have a Potterton EP6000 central heating programmer that has decided to stop working I think?
Basically if I turn the hot water on it works fine and starts up the boiler. But if I turn the central heating on then nothing!
I removed the panel from the wall and took the backup battery out and left it a bit then put it back on the wall, initially it worked again but second
time of trying it nothing.
So I think it's the programmer gone rather than anything else!
Am I missing something obvious
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
HowardB
| posted on 1/1/12 at 12:48 PM |
have you checked the boiler and any manual over-ride that there might be?
Hth
Howard
Howard
prelude1980
| posted on 1/1/12 at 12:57 PM |
Hth
Howard
I can't find any manual overide but the hot water side works so I don't think its the boiler
gets you.
| posted on 1/1/12 at 01:01 PM |
If you're confident to do this then you could take the wires off the connector on the controller and short out the ones for the CH. Obviously do
this with the electricity off. Then switch on the electricty and you should get CH. If you don't the problem is not the controller. If it works
it's the controller, probably just the relays. You can get a replacement called the EP6002 which fits the same backplate but it slightly less
antique.
Madinventions
| posted on 1/1/12 at 02:19 PM |
May sound obvious, but is your thermostat working correctly?
View my band website:
http://www.shadowlight.org.uk
daniel mason
| posted on 1/1/12 at 02:20 PM |
could be a faulty/stuck zone valve!
mark chandler
| posted on 1/1/12 at 02:31 PM |
Does sound like the motor valve to me this will be alongside the emmersion tank and switches the supply around
lewis
| posted on 1/1/12 at 02:52 PM |
Been having simmilar problems with mine,lights & timer come on but does not send the signal to the valve,if I give mine a 'tap' it
kicks into life again and moves the valve,new controller/programmer on order for me.
I am a driving god!..........sort of
prelude1980
| posted on 1/1/12 at 02:54 PM |
antique.
I just tried shorting the CH and it did start working so i just ordered the EP6002 as it makes changing everything very easy!!
Slightly less antique did make me chuckle!! i think the controller i have must be 20 years old
Thanks for the help
[Edited on 1/1/12 by prelude1980]
gets you.
