mangogrooveworkshop
| posted on 16/8/04 at 05:25 PM |
Snazzy Signature software!
http://www.danasoft.com/index.php
You're probably here because of my signature.
Written on a whim, this signature is now used on more than a thousand websites around the world!
The signature image is generated in real-time for each user that views it. Your IP address and other information are only visible to YOU, not to
others! Read the privacy policy for more details. The purpose of the signature is to spread awareness about what information all websites can gather
about you.
In the coming weeks I'll be adding more languages, more customization features and more options to enhance your online image.
DanaSoft is creating the place to make or get your own original signatures and avatars!
So who is considribbly!!!
Your ISP may not be who they say they are as they often lease from the larger ISPs. TESCO uses NTL! and so on.
Bit of fun! Awake up call>
phelpsa
| posted on 16/8/04 at 05:38 PM |
Shhhhh, I use tesco.
Adam
stephen_gusterson
| posted on 16/8/04 at 07:43 PM |
schhh
i use NTL!
atb
steve
mackie
| posted on 17/8/04 at 08:42 AM |
Some ISPs (certainly NTL do) use transparent web proxies. Also if you are on a lan or use a home broadband router of some description your computer is
likely to have a private IP address which is translated by the internet gateway. Thusly your IP address will appear as the NAT gateway or proxy
nearest to the signature generating software.
