<<  1    2  >>
Author: Subject: Lathes - What have you made for your car ?
T66
posted on 23/1/12 at 07:17 PM Reply With Quote
Just recently got myself a lathe, would be interested to see some of the car related jobs you have created.
big_wasa
posted on 23/1/12 at 07:34 PM Reply With Quote
very boring, spacers and more spacers. I did turn one very nice dcoe to bike Tb adapter but got bored and never made the other matching three.
posted on 23/1/12 at 07:38 PM Reply With Quote
Spacers, adapters, gearknobs..
Next is a steering wheel boss and some indicator stalks...
Thats after the sump, gearbox, front wings and stays, some gauges and roll cage have been sorted...
NigeEss
posted on 23/1/12 at 07:52 PM Reply With Quote
Wishbone bushes, fishmouths on round and square tubes, coolant and oil pipe connectors and lots of spacers.
Should start taking piccies of things !
clanger
Fitter & turner by trade, and worked in a place with lots of lovely aluminium when I built my first car, recipe for disaster (from the company's productivity point of view!!!). If I could get in a chuck I made it
Steering column & shroud
Spacers
Nutcovers
hub covers
trackrod extensions
bushes
core-plugs
bearings
bearing housings
widgets and wass-inames
catch tank (out of a nice piece of 6" billet)
hose joiners
gear knobs, several different designs
plus other stuff I forgotten about............
Go MAD
AdrianH
posted on 23/1/12 at 07:57 PM Reply With Quote
Steering rack extensions.
Cleaning up flywheel (machining face).
Brake drums, disks changing centre hole. Truing up etc.
Spacers and crush tubes.
Steering shaft adapters.
Boring pulley centres
Injector boses
Various jobs for various cars!
Adrian
Why do I have to make the tools to finish the job? More time then money.
T66
posted on 23/1/12 at 08:01 PM Reply With Quote
Spacers
Nutcovers
hub covers
trackrod extensions
bushes
core-plugs
bearings
bearing housings
hose joiners
Go MAD
" If I could get in a chuck I made it" hahahaha - Bench going in next week, just need to go get some scrap to play with.
The Amateur lathe is in the post, my mind is racing already.
owelly
posted on 23/1/12 at 08:03 PM Reply With Quote
Steering wheel bits:
Bits for Type 9 hydraulic clutch gubbins:
Skimming manifold flanges:
Spigot centre for flywheel:
PugV6 to Type 9 adapter plate:
Adapter locating spigot:
Wheels for beading tool:
Skimmed Sierra rear hubs to take Escort discs:
Bits for De-dion:
MGF solid subframe mounts:
There's hundreds more things I've had in the lathe (including me) but you get the idea? I like my lathe.
http://www.ppcmag.co.uk
T66
posted on 23/1/12 at 08:12 PM Reply With Quote
You have a daddy lathe, mines just a small one.
owelly
posted on 23/1/12 at 08:31 PM Reply With Quote
For a lot of stuff, a smaller lathe is better than a big 'un! A gap-bed is the best of both worlds. Sometimes its hard to explain to folks that a lathe can be used for making things flat, as well as round!
AdrianH
posted on 23/1/12 at 08:34 PM Reply With Quote
So where is Clairetoo's input?
Adrian
clairetoo
posted on 23/1/12 at 08:44 PM Reply With Quote
Adrian
Who....me ?
I'm in the `if it fits in the lathe , I'll have a go' camp - I've done everything from small spacers to billet alloy flywheels - and before I got a small miller , a bit of milling as well . Being a time-served turner/toolmaker has come in kinda handy over the years !
On my Fury at the moment are - alloy front hubs (to fit Rover 820 285mm discs) , alloy flywheel and all engine pullies , modified throttle bodies on angled adapter plates (which were skimmed to the required angle on my `big' lathe) , and a quick release steering wheel boss .
The lathe(s) are getting a bit of use on the Mx5 project as well........
Its cuz I is blond , innit
Claire xx
Will weld for food......
MikeR
She'll still be in the garage on the lathe .....
big_wasa
posted on 23/1/12 at 08:46 PM Reply With Quote
worst thing I did, swaping my old english lathe for a little chinease one but I couldnt keep it and build the car in the garrage.
clairetoo
posted on 23/1/12 at 09:02 PM Reply With Quote
Just to show the range of stuff you can do with a lathe - this was part of a large `tool' for a fibreglass molding I was making at work , this part needed to be round and tapered - its 14" diameter and some 5" long made from several layers of MDF glued together ,
And a quick release steering wheel adapter for some one on here .
Claire xx
Stott
posted on 23/1/12 at 09:07 PM Reply With Quote
Ha ha!
Check this out for material wasteage, Peugeot 205 rear beam bushes from Phos Bronze billet, it was the only bit on the rack!
Waste Of Material?
Waste Of Material?
T66
Appears your lathe is bigger than my lathe too Claire - I like the steering wheel QR
ashg
posted on 23/1/12 at 10:05 PM Reply With Quote
beginnings of the spacer i made for the omega box to get it to work with the saab clutch, cant seem to find a picture of the finished item
you can almost see it here behind the slave cylinder
made a plug for the heater circuit that i eventually took out and bypassed as the motor kept overheating lol
90 degree elbow for my saab waterpump that i tigged onto the cast housing.
custom trigger wheel for my old pinto engine
holes through m8 bolts to make indicator extensions
wishbone parts
headlight mounts
custom made steering shaft
plus thousand of other parts.
last week i made some spacers for nash's suspension. the month before that i mad some spring platforms for mark's tiger, also made mark and dick some crush tubes for the control arms on their tigers. the list goes on and on and on. btw my harrison lathe is a gap bed, i have managed to skim the head of a fiat punto on it with a bit of mucking about
[Edited on 23/1/2012 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
ashg
posted on 23/1/12 at 10:23 PM Reply With Quote
couple more aluminium sparkles
rf900rush
posted on 23/1/12 at 10:32 PM Reply With Quote
Would not be with out a small lathe.
A few spacers
Clutch Slave for GSXR1100 / RF900 ( a bit of milling on this one).
Both machines are cheap chinese thing's.
Slave
Slave
O2 Lambda Nut thingy.
Nut
Nut
Now with added CNC control. does need some improvements but,
managed to make a Bike Led lamp.
Best bit was doing a 51mm buy 1mm thread for the lense cover.
coyoteboy
posted on 23/1/12 at 10:39 PM Reply With Quote
Only this of any real interest so far, and not my lathe... I wish I had one!
New sensor by j.buckle, on Flickr
ashg
posted on 23/1/12 at 10:43 PM Reply With Quote
Ha ha!
Waste Of Material?
Waste Of Material?
can really tell who has to pay for materials
the lump of square steel i machined in to a slave cylinder spacer was found in the work carpark, they are used as counter weights on the machines we make, some twonk had used loads of them to hold a tarp down in the carpark. once the paint finish on them is battered from being used in that manner they were all considered as scrap as its too much bother to sand them all down and repaint. fortunately i was there to help the facilities guys clear them up into the scrap bin. the only other material we really have at work is 99.999999% pure copper which is used to make the rf wave guides on the particle accelerators. they are machined to a tolerance of 6 microns and the material is so expensive the cnc laves are hovered out for swarf and its melted down and reused for slightly less critical components of the machine. think last time i looked at the price of medical grade pure copper it was £1000 for a piece that is 100x100mm 1mm thick :S dont think i would get away with wasting any of that
Wadders
posted on 23/1/12 at 11:06 PM Reply With Quote
This lot was all done on an old 3 1/2 " lathe, eventually upgraded to a bigger harrison machine, but the smaller lathe was great for learning on. You can lose hours making stuff with lathes, best tool ever invented.....great fun.
[Edited on 23/1/12 by Wadders]
907
posted on 24/1/12 at 08:39 AM Reply With Quote
I can't think of a single item that I 100% made on my lathe.
Rack extensions and fuel filler cap almost, but still needed a bench drill.
A lathe is however a tool that makes other things a lot easier to fabricate.
Wish bones for instance.
Facing off the bush tubes, nice and square. Tapping the M18f threads.
Even the "fish mouth" tube ends can be done with a milling tool in the chuck.
And those much talked about crush tubes lengths? A doddle to get those right.
It's not just the lathe though. You need all the tooling that goes with it.
Paul G
kipper
posted on 24/1/12 at 08:58 AM Reply With Quote
myford lathe
sorry to hijack this but I still have my Myford ML7 for sale since I bought my Harrison L5.
I could really do with it out of the workshop and will be putting it on Ebay shortly.
It has had very little use as the Harrison came up just after I had bought the Myford.
The man who had it before me had retired and bought the lathe to make a model steam engine but he fell ill shortly after starting it and never got to finish it.
It then stood in the house until his widow died ,I bought it from the son when he cleared the house.
It has a brand new 3 jaw chuck ,a 4 jaw,vertical milling slide,catch plate,quick change tool post,Face plate, is on riser blocks, has graduated lead screw, plus lots more bits and pieces.
Pics of lathe in my archive.
Regards Denis
Where did that go?
<<  1    2  >>
