Author: Subject: Any 2 stroke experts in the house?
mookaloid
posted on 2/3/12 at 10:53 AM Reply With Quote
Hi folks
got one of these Description
and it wont start
I have changed the spark plug and put fresh fuel in but no joy - worse than that I have blisters on my fingers from pulling the cord
Any suggestions please?
Put it in the bin and buy a new one cos it's an antique might well be the answer here
Mark
wilkingj
posted on 2/3/12 at 10:59 AM Reply With Quote
Have you checked to see if you have got a spark?
Have you tried a different plug ie its breaking down under compression?
Is there any compression?
Is the petrol fresh?
Have you tried it with a squirt of WD40 in the carb inlet or a whiff of Propane or Butane from a blowlamp (with no flame of course )
I have often tested old engines that have been standing for a long time and the fuel has gone stale, or the carb is blocked.
The Gas in the Intake gets round all those issues and proves the engine will run.
Just dont do it for a long period, as there is no lube oil in WD40 or Propane / Butane, after all it is a 2Smoke .
Its a good check, we used to do this at my mates jetski business, as its simple to do, and bypasses all the fuel system.
If the engine fires up, then check the fuel system.
Daft Q's really...(sorry)
Just my 2 Reils worth.
[Edited on 2/3/2012 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
r1_pete
posted on 2/3/12 at 12:55 PM Reply With Quote
You have primed it haven't you? there is usually a plastic squishy bulb which you pump until it goes hard (oo er missus) to pressurise the fuel, exhaust heat keeps it pressurised.
posted on 2/3/12 at 01:10 PM Reply With Quote
There's plenty of oil in WD40, probably more than a 20:1 petrol/oil mix, though how suitable it is for a 2 stroke is another matter!
Start with the obvious - is there a spark, and is fuel getting through (does plug get wet)?
JAG
posted on 2/3/12 at 01:19 PM Reply With Quote
Check;
Is there fuel getting through? does the plug get wet if you try to start it? If you turn the engine over does the air coming out of the exhaust smell of fuel?
Is there a spark? Take the plug out, earth it somehow and then turn-over the engine - do you get a spark?
After that I'd probably take the carb' off and just check there's no old fuel residue blocking any jets. This is most likely if the engine runs on pre-mix fuel/oil and has been standing for a while. Give it all a good clean inside and put it back together and try again.
Next check how the spark is generated; CDI or magneto type ignition? Magneto's have points and adjustment or lack of can lead to no spark.
Keep plugging away (pun intended) like this and eventually it will probably fire. Two-strokes are such simple things it's unlikely to be broke beyond repair.
My chainsaw (similar size and age) was a skip find - but a little bit of work soon had it running and it's now been a great tool for over 10 years
Justin
posted on 2/3/12 at 01:22 PM Reply With Quote
Top handle saw with no chain brake, don't start it is my recommendation.
RichardK
posted on 2/3/12 at 01:39 PM Reply With Quote
Yeh as said,see if you can chack for compression or just break it down and pay special attention to the carb using carb cleaner and an air line a thin wire.
About the only thing you may struggle with is if the crank seals have perished and you no longer have crank case vacuum, everything should be easily spotted when apart.
Fetch it round and I'll have a shifty at it
R
Gallery updated 11/01/2011
posted on 2/3/12 at 03:31 PM Reply With Quote
Good point - not the most user friendly of machines.
mookaloid
posted on 2/3/12 at 04:45 PM Reply With Quote
ok
It has a spark - brand new plug fitted today
it has compression
fuel is getting through because it comes out of the exhaust after several pulls. - I have stripped the carb and it looks brand new certainly not blocked in the jets
there's no primer.
Can't see any points - are they under the flywheel cover thingy?
Crank seals might be shot but without stripping it down I can't tell
Perhaps you could pop round Rich and have a look?
RichardK
posted on 3/3/12 at 11:56 AM Reply With Quote
How much compression, min for me would 130 ish psi?
Not coming round to yours,right dodgy area,blokes in balaclavas wanting to rob you
When you moving out?
Rich
batteredoldsupersport
posted on 3/3/12 at 01:44 PM Reply With Quote
I'm new here and no 2T expert. However the usual snag at this time of year is the carb bunged up with stale oil and fuel. Before you start stripping it down you can often get them going by fitting anew plug as this will be gummed up too. If you can't get a new plug take it out and give it a good heating in a gas flame, it burns the crud off and this sometimes helps.
posted on 3/3/12 at 04:49 PM Reply With Quote
Getting the plug really hot, putting it back while still hot and pulling the starter is always worth a try.
I hate 2-strokes - they're fine when they work, but absolute bar-stewards when they don't, especially if they've been flooded at some time.
owelly
posted on 3/3/12 at 05:47 PM Reply With Quote
If there's a spark, the flywheel could have moved on the crank. Woodruff key failed or some just grip on the taper. Plug wet or dry?
http://www.ppcmag.co.uk
