Author: Subject: anyone know about bosch washing machines
daniel mason
posted on 17/6/12 at 06:35 PM Reply With Quote
im having trouble with my bosch maxx 5 washing machine. the other day i tried to open the door about half hour after the wash had finished but the handle would not open the door. so i did what any man would do and pulled it harder until it opened. when the door opened a small plastic part which held the handle to the locking mechanism broke off. meaning the only way to open the door was to use a screwdriver to depress the spring to open the door which i have been doing for a week or so.but now it just wont work at all.it wont start to fill, and therefore is not even starting the cycle.
any ideas?
plentywahalla
posted on 17/6/12 at 07:02 PM Reply With Quote
The door lock is interlocked to the cycle controller.
That means that the machine thinks the door isn't shut so it won't start. Try jiggling the door up and down, or giving the door lock a bit of a thump. It's only a microswitch which isn't making contact. Your poking around with a scewdriver has probably done a bit of damage to the locck.
Rules are for the guidance of wise men ... and the obedience of fools. (anon)
dave
posted on 17/6/12 at 10:12 PM Reply With Quote
You probably need one of these.
http://www.espares.co.uk/part/washing-machines/door-parts/bosch/p/1556/856/0/0/1123431/mechanical-door-interlock.html
daniel mason
posted on 18/6/12 at 06:22 AM Reply With Quote
i managed to take it to bits last night and fix it. the whole door lock mechansm had been pushed inside the machine. all i need now is a new handle. cheers guys
