Chaz
| posted on 23/7/12 at 10:50 AM |
Zetec plenum and manifold
I need a zetec plenum and manifold for my 1.8 silver top which I'm currently supercharging.
I thought I could use my Bogg bros (bike manifold) but i don't think it's going to align with any injector rails on the market
Any advice with combinations of zetec manifold/injector rails will be greatly recieved.
Thanks in advance
Chaz
| posted on 23/7/12 at 11:24 AM |
P.S - the cheaper the better, I'm on a budget right now! And we are on locost builders!
Happy considering the DIY approach.
will121
| posted on 23/7/12 at 11:37 AM |
whats the issue with fuel rail? as link below some can help on here with making a specific fuel rail to suit your spacing
fuel rail blanks link
Chaz
| posted on 23/7/12 at 11:44 AM |
The bike manifold I have brings all the inlet pipes closer together. Too close for 'standard' fuel rails to fit
mcerd1
| posted on 23/7/12 at 12:04 PM |
what about the bike's std. fuel rail ?
Myke 2463
| posted on 23/7/12 at 12:35 PM |
Whats wrong with the std plastic manifold ? Omex used it with their supercharger i believe.
Be Lucky Mike.
Chaz
| posted on 23/7/12 at 01:24 PM |
Plastic? Which one do you mean? Are you referring to the duratec inlet manifold?
mcerd1
| posted on 23/7/12 at 01:37 PM |
I assume he's thinking of the blacktop zetec E manifold found in the focus's etc....
the ST170 manifolds (also plastic) could be made to fit bike TB's if I remember right.... (not sure if they'd fit a silver top though ?
[Edited on 23/7/2012 by mcerd1]
Chaz
| posted on 23/7/12 at 01:40 PM |
Oh ok, I don't think the inlet to silver top and black tops are the same.
jeffw
| posted on 23/7/12 at 03:37 PM |
Use a stock ST170 manifold, respace your bike TBs to suit (I assume you have these?) and then a Nissan GTi-R Pulsar plenum (£45 from breakers). Get
Flackmonkey to make you a tb to plenum adaptor plate and you should be sorted.
Chaz
| posted on 23/7/12 at 05:26 PM |
Good idea but I've sold the bike carbs. I'm trying to go for an all in one manifold and plenum with a single throttle body.
jeffw
| posted on 23/7/12 at 08:19 PM |
Well the Omex one might use plastic intake but it has a Jenvey plenum which is over £500.
The cheapest way would be ST170, GSX Throttle Bodies, GTiR plenum and then what ever supercharger you can get on it. Look at flakmonkey Duratec
supercharge built. Ultimately this will not be cheap...And I wouldn't bother doing it to a 1.8. Better off getting a 2.0 Blacktop and throw
some cams in it. It will make 190ish which is about the same as you will get with a 1.8 homebrewed supercharged and it will cost you a hell of lot
less to do (overall).
[Edited on 23/7/12 by jeffw]
[Edited on 24/7/12 by jeffw]
Chaz
| posted on 23/7/12 at 08:29 PM |
Oh ok, some sound advice! Thank for the big picture stuff, that's a helpful counter option.
